Go to Post We are all insane aren't we? I just want to build a robot now. :P - Lowfategg [more]
Unread 11-01-2016, 19:16
bt20304 bt20304 is offline
FRC #2137
bt20304 is an unknown quantity at this point
Re: pic: Effective Aperture of Low Bar Defense
hey, looking at measurements in solidworks, you seem to be off.
in reality the field elements are 13.73" measured the same way
https://drive.google.com/open?id=0B4...G5rM1Q0YlNCYmc
Unread 11-01-2016, 19:31
pHolmgren's Avatar
pHolmgren pHolmgren is offline
AGM
AKA: Preston Holmgren
FRC #2557 (SOTABots)
pHolmgren has a spectacular aura aboutpHolmgren has a spectacular aura about
Thanks for this! It really helped us visualize what's needed for a low bar robot.
Unread 11-01-2016, 21:22
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
When I measure against the field model provided by Autodesk, I get 13.86". Did you model those elements yourself or were they taken from elsewhere?
In any case, that discrepancy is why I added a disclaimer in this thread saying that y'all shouldn't take my word for it and should check things out yourselves.
--Madison--
...down at the Ozdust!
Unread 11-01-2016, 22:53
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by Nebster View Post
I was thinking about this too. Something where the front end of the robot is less than the ~14" limit for when the robot is on the ramp, but the rest of the robot can go up to 15.9" or so and be fine.
Warning- MS Paint incoming:
Those slopes would go a lot farther back, depending on how long the robot is and where the CG is. The initial approach would actually have a better aperture, since you're on your front wheels and rear wheels, and thus at a shallower angle. Then the aperture would shrink down to whatever that minimum amount is, until your CG (or something else) tilts you down to horizontal again.
Coming from the backside is even worse. If you're not flat before you get to that bar, you're going to have to be something like 3" shorter yet. so that end of your robot will have to be 11" or maybe even 10".
The real answer to all this, of course, is to make up an inventor sketch of a side view of the low bar and your chassis and layout. And then run your chassis through with wheels tangent to the correct surfaces, and see what happens.
Unread 12-01-2016, 09:32
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Thanks for posting this. This was a fact some teams were able to catch very early, but unfortunately we all know we are going to get to events and see a 15.9" tall robot with a strategy designed around a nontrivial utilization of the low bar.
Unread 13-01-2016, 10:39
pHolmgren's Avatar
AGM
I know it must be do-able but the challenge is fitting a firing mechanism in that space, to shoot in the high goal.
Unread 13-01-2016, 10:42
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
EricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond repute
Unless your drive base is the exact length of the defense ramps your robot isn't going to be on a 13.5 degree angle.
I suggest all teams put in their robot in a sketch and run it through like it was actually driving through the low bar. The height of that bar isn't as low as people are making it out to be if your drive is designed correctly.
2002-2005 Appleton East High School: Team 93
2005-2011 Michigan Technological University: Team 857
2012-2016 Wave Robotics Team 2826
Unread 13-01-2016, 10:45
pfreivald's Avatar
AKA: Patrick Freivald
I realized this problem right away, but appear to have gotten the orientation of the low bar backward--I thought the bar was closer to the Courtyard, rather than to the Neutral Zone. Thanks, Madison!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 16-01-2016, 13:29
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
All the Field models were provided by FIRST and imported into SOLIDWORKS.
AndyMark and VEX Robotics models were designed originally in SOLIDWORKS and provided by these manufactures directly to us to create our KOP.
Industrial suppliers such as SMC BIMBA FESTO also have validated models on 3DContentCentral.
You should always verify models. Good engineering practice. Marie.
Unread 16-01-2016, 15:49
This depends somewhat on your CoM. If you have a CoM near the back, you might not fall down horizontal until you're well into the low bar. At which point you'd start pushing against the low bar. Just CAD isn't going to give you those details.
Unread 19-01-2016, 13:22
dsergison dsergison is offline
FRC #1756
dsergison is an unknown quantity at this point
it's worth drawing up for your own wheelbase... 6 or 8 wheel bots likely have 24-36" wheelbases, so they never sit on the ramp at the ramp angle, so their effective aperture is not quite as bad as shown....
also, the aperture isn't symmetrical.
It's a weird obstacle for sure. It will be interesting to see how people hang up on it. It has a lot of potential to completely jam some bots for the duration.
