Go to Post You get to see great matches at the Championship event regardless of a people's choice event. - Yan Wang [more]
Unread 01-13-2016, 09:24 PM
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Re: pic: 3280 Tape Measure Hanging Mechanism
How do you drive the tape upward? do you some type of rollers?
Unread 01-15-2016, 01:29 PM
gryphon97's Avatar
gryphon97 gryphon97 is offline
FRC #5430 (Pirate Robolution)
Rookie Year: 2016
gryphon97 is an unknown quantity at this point
Originally Posted by JamesBrown View Post
Yeah, that's the one.
I will see if I can find some pictures of the hook tomorrow.
Have you been able to find the additional pictures?
Any other details can you give us?
Thanks.
Unread 01-15-2016, 01:31 PM
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Hey guys. This team is no longer in existence. Miki Oliver was the lead mentor/coach for 3280. He is on a rookie team now in RI...but he doesn't come on CD. James Brown is probably the only person I know that I believe saw the device in action back 2010...he might still have pictures.
FRC78: 2010-Present
FRC121: 2002-2009
Unread 01-15-2016, 02:36 PM
Adventuregirl Adventuregirl is offline
FRC #2090
Adventuregirl is an unknown quantity at this point
For the FTC Res-Q, on my home-school team, our idea was extremely similar. We used a thicker, stronger measuring tape and screwed it onto drawer sliders made of steel and it extended more than 5 feet in length. The measuring tape hanging mechanism is a great idea.
Unread 01-15-2016, 05:18 PM
Cam877's Avatar
Cam877 Cam877 is offline
Mechanical Design Captain. Go MORT!
AKA: Cameron Hallihan
FRC #0011 (MORT)
Cam877 has a brilliant futureCam877 has a brilliant futureCam877 has a brilliant futureCam877 has a brilliant futureCam877 has a brilliant futureCam877 has a brilliant futureCam877 has a brilliant futureCam877 has a brilliant futureCam877 has a brilliant futureCam877 has a brilliant futureCam877 has a brilliant future
How is the hook attached to the end of the tape measure?
Unread 01-15-2016, 06:34 PM
Mikyway Mikyway is offline
FRC #5587
Mikyway is an unknown quantity at this point
The tape idea seems really good if you're looking for a compact lifting mechanism, which we are. But our team was a rookie last year so we have no idea how to go about doing this. Are there any kits or parts that you need to get for this, and if not how would you go about making one?
Unread 01-22-2016, 07:05 PM
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron)
How did you keep the tape measure from releasing once you had pulled your robot to the height you wanted it? Was it some kind of locking mechanism or was your spool on a worm-drive or non-backdrivable gearbox.
Could you post a picture of the other side of the gearbox?
John Fogarty
Unread 01-22-2016, 11:34 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by Knufire View Post
Thirded.
I haven't done one of these myself so I may be completely wrong, but this is what I understand between what I've read and in attempting a tape measure potentiometer last year:
Tape measure rules are flat sheets of (essentially always) steel. These sheets are rolled onto the axle inside the tape measure unit in a flat configuration where they bend quite easily, but are bent a few degrees (typically about 10 or 15) as they leave the tape measure through a curve molded into the case so as to provide stiffness against the tape buckling. Stanley Fat Max appears to be the best on the market at this function.
Tape measures are meant to be pulled, not pushed. The challenge then becomes one of driving the unrooling of the spool at the shaft end before the curvature is added, or driving the tape after it is curved without ruining that curvature (this should be easy for teams who can sculpt a wheel's profile on a lathe).
Unread 01-22-2016, 11:55 PM
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
If you push fast enough, they don't seem to care.
https://www.youtube.com/watch?v=rNyMEM3njrM
http://www.youtube.com/watch?v=qJFQkBGCgaE&t=0m19s
This mechanism just ran a 1.625" rubber Banebots wheel against a tape measure. It was flat at the drive wheel, but had a long support that allowed the tape to curl back up.
Unread 01-30-2016, 06:41 PM
Codster3922's Avatar
Codster3922 Codster3922 is offline
AKA: Cody Smith
FRC #2130 (Alpha+)
Codster3922 is an unknown quantity at this point
Hey guys i was wondering if you guys have a CAD file for the tape measure kit. If u do plz msg me or comment back. Thanks.
Unread 01-30-2016, 08:49 PM
RoboAlum RoboAlum is offline
Mickey D's
FRC #4841 (Optimal Robotics)
RoboAlum is a jewel in the roughRoboAlum is a jewel in the roughRoboAlum is a jewel in the roughRoboAlum is a jewel in the rough
I know we are taking on the challenge of making a tape measure climber. We hope to post video and pictures soon we are prototyping with a few tape measure a dewalt 1-1/4", Milwaukee that is nylon coated and a Stanley max steel. We're using a vex 3 motor single reduction gearbox 84/12 and tiny colons from vex.We will share our findings
Co-Founder and Director
RASA (Robotics.Alliance.of Southern Arizona) 501c3
FRC 4841 2013-
VEX 4874 2013-
Student
FRC 71 2010-2013
pic: 3280 Preparing to Hang (by tape measure) JamesBrown Extra Discussion 12 03-30-2010 11:14 PM
Tape measure anyone? Adam.garcia Technical Discussion 13 02-06-2010 02:14 PM
The First Tape Measure Olympics mlah Chit-Chat 15 04-14-2009 10:03 PM
Where's the Tape Measure? Jeff_Rice Chit-Chat 24 02-16-2003 12:49 AM
Tape measure proboscus tito General Forum 24 04-29-2002 03:56 PM
