Go to Post I'm sure someone somewhere worked [I]really hard[/I] on this and I congratulate them for the attempt. Unfortunately, its one of those things that should be taken down and recorded in the company journal as a bad idea. - Katie_UPS [more]
Unread 17-01-2016, 20:32
TheSousaLife's Avatar
TheSousaLife TheSousaLife is offline
Team Role: Scout
Rookie Year: 2015
TheSousaLife is an unknown quantity at this point
Is Bowling thought the Low Bar legal
So I have been in the FRC Stronghold Manual. I found nothing regarding the legality of bowling through the low bar. I did see that the bar was designed so you could not bowl through them. However, if you did, would you be penalized??
Unread 17-01-2016, 20:36
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: Is Bowling thought the Low Bar legal
Update two made it explicitly illegal as per G40. Although it was more or less illegal before then.
EricH EricH is offline
If you were to somehow get the ball through or over the cloth, which happens to be weighted down with a metal pipe, using a rolling bowl from 27' away, up a ramp, I can find no rule that would currently provide a justification for a penalty, unless you had a robot hold the cloth open (G40-1, tech foul).
However, I think the laws of physics indicate that doing so is going to be very difficult at best.
Edit: just saw ratdude's post. Sorry, mate, but G40 only applies to a ROBOT sending the Boulder through, while the OP is talking HP, I do believe.
Unread 17-01-2016, 21:23
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
No rule prohibiting bowling through low bar or even launching over it from HP Embrasure to Opponent courtyard...but good luck with that
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star #21 | Galileo Division #91
Unread 17-01-2016, 21:29
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Originally Posted by Boltman View Post
No rule prohibiting bowling through low goal or even launching over it from HP Embrasure to Opponent courtyard...but good luck with that
I would submit the question to the Q&A for a definitive answer, but I believe that G33 B and C saying "Boulders may only be introduced to the FIELD during TELEOP by a DRIVER or HUMAN PLAYER, and through one of the holes in the HUMAN PLAYER STATION.
Violation: FOUL per BOULDER
Academic Student (Forever)
Unread 17-01-2016, 21:32
The Embrasure is one of those holes (actually two, because there are two Embrasures and one Brattice). What he's saying is that there's no rule prohibiting a particularly hard kick/bowl/Boulder Propulsion Method from going through/over the opponents' Outer Works, specifically the Low Bar (which is NOT to be confused with the Low Goals)--which is true. I think Physics is more of a Law than a Rule.
Unread 17-01-2016, 21:33
CalTran's Avatar
Missouri S&T Senior
Oh, right. I read it as launching over the HP station. My bad.
Unread 17-01-2016, 21:41
nickyflash's Avatar
nickyflash nickyflash is offline
Boulder Thrower
AKA: Nicole D.
FRC #0692 (The Fembots)
nickyflash is an unknown quantity at this point
I would be quite surprised if a Boulder could ever go from the embrasures past/over the Low Bar. I haven't tested it yet, but maybe there could be the slimmest chance that the Boulder could swerve right and travel past Defense #2. (G40 is not violated)
I boils down to .....
"The OUTER WORKS impede the passage of ROBOTS and BOULDERS into the COURTYARD. ROBOTS move BOULDERS across the OUTER WORKS into the COURTYARD one-at-a-time. "
"The OUTER WORKS.... is designed to impeded the passage of ROBOTS and BOULDERS in to the COURTYARDS"
There are RULES (G40) for Robots and NONE for Human Players.
So in Theory IF a Human Player can get the boulder from one of the two holes in the EMBRASURE and into the opponent courtyard you just beat the design to impede that and NO FOUL.
And good luck with that. We want you on our alliance.
Unread 17-01-2016, 22:00
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
To be a little less cryptic. Update 2 added rule G40-1 prohibiting a robot holding/propping the low bar flap open and the drive team rolling ball through it. So while not specifically prohibited, bowling a ball through the low flap would be difficult.
If you don't know what you should hook up then you should read a data sheet
Unread 17-01-2016, 22:09
Edxu's Avatar
Edxu Edxu is offline
Scouting/Strategy Lead
AKA: Edwin Xu
FRC #0610 (The Coyotes)
Edxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud of
If you really wanted to game the system, one thing you could do is have your ROBOT grab the cloth and instead of holding it open, simply hold it taut at an angle such that when the Human Player punts the ball through the embrasure, the cloth of the Low Bar behaves like a ramp, propelling the ball over.
Although it then causes some ambiguity over the definition of "open" and "closed": "not closed or barred at the time, as a doorway by a door, a window by a sash, or a gateway by a gate: " - Dictionary.com
2013 FRC World Champions (1477, 1241, 610)
Queens University Computing Class of 2020
6-??
Unread 17-01-2016, 22:13
timtim17's Avatar
timtim17 timtim17 is offline
Programmer
AKA: Austin
FRC #1294 (Top Gun Robotics)
timtim17 has a spectacular aura abouttimtim17 has a spectacular aura abouttimtim17 has a spectacular aura about
Q528 caused it to be illegal, creating G40-1 in update 2.
It's clearly a hardware problem.
1294 || Programmer // 2015 - Present || Board // 2017 - Present || Webmaster // 2017 - Present
Last edited by timtim17 : 17-01-2016 at 22:14. Reason: moved a space out of a link
Unread 17-01-2016, 22:21
Chak Chak is online now
AKA: Thomas
FRC #4159 (Cardinalbotics)
Q528 makes it illegal for a robot to hold the low bar open so that a HP can bowl the ball pass the low bar. The OP is asking about the HP bowling the ball pass the low bar without assistance. As others have said, this is probably physically impossible, but not explicitly illegal right now.
Originally Posted by Q528
However, it conflicts with the intended game play whereby BOULDERS are brought to COURTYARDS by ROBOTS
And I wouldn't want to go against the GDC's intent anyways. I'm pretty sure that if you decided to Q&A this, you would receive the same answer as Q528 except it's a different (and more difficult) loophole.
Unread 17-01-2016, 22:23
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Instead of the robot holding the cloth, how about the robot in the shape of a wedge, and the boulder "hits" the robot and "bounces" over the low bar?
Unread 17-01-2016, 23:01
AKA: Thomas
Similar to the OP's solution, I think that this would probably be physically impossible.
Even if you figure out a way to do it, this robot would be violating G40.
Originally Posted by G40
A ROBOT may not cause a BOULDER to move from the NEUTRAL ZONE into the opponent’s COURTYARD unless:
A. the ROBOT contacts the BOULDER within OUTER WORKS, and
B. the ROBOT completes its CROSSING (i.e. doesn’t completely back out of the OUTER WORKS into the NEUTRAL ZONE)
You would receive a tech foul per boulder, unless this robot follows every boulder through the defense. In that case, any robot with an effective floor intake would be able to perform the same function in a more feasible way.
