Go to Post FIRST is an organization where you leave lasting impressions on people you don't even know. - rtfgnow [more]
Unread 18-01-2016, 01:57
nuclearnerd's Avatar
AKA: Brendan Simons
FRC #5406 (Celt-X)
Re: pic: D-Bug 3316 Stronghold Shooting Chart
Originally Posted by nuclearnerd View Post
Do you calculate the angle to the goal, and then multiply the aperture by the cos of the angle? Or do you calculate the included angle from the bot's point of view? If it were the latter, I would have expected the circles to get smaller from far away
Here's what I'm talking about. The table below looks at a slice of space perpendicular to a high goal. It calculates the included angle of the "gap" between ball and goal, in horizontal and vertical (and the minimum of each below). As you can see, the goal appears larger as you get closer and higher (something your chart doesn't do afaik - I can't check your math as I don't have excel on this machine). There is a sweet spot 4' up and 3' back from the goal where the gap appears as big as 8 degrees (if I've done my math right)
https://docs.google.com/spreadsheets...it?usp=sharing
