Re: pic: 2869 2016 Chassis
Right now our motor count is at 2 775Pros, and 4 Cims. Not to mention an onboard compressor. 2 of the motors (775's)will be used on a shooter 1 of the motors(Cim) will be used to articulate the shooter another 1 of the motors(Cim) will be used to articulate a piston (Only for endgame). and the 2 other two cims are on the drive train. We are going to mount electronics on the chassis today and test it out. If we have to add 2 more cims it is not an issue but we will be maxing out our cim count and Brownouts will be a fear. |
6 CIMS (On your DT) is where you should be concerned about brownout, not 4. If you can find it in your budget, try to acquire more CIMS, or strongly reconsider your current motor allocations.
Last edited by Navid Shafa : 20-01-2016 at 13:16. Reason: Clarification/Addition |
This. Please, before its too late, put 4 cims in your drivetrain. Brownouts shouldn't be a concern unless you are running a 6cim drivetrain and 2 775 hanger while in a pushing match against a new England team.
Looks nice! Just a bit of friendly advice, you probably want to put your bolts in from the outside, not the inside. Especially in a game of compact robots like this year, removing one of those long axle bolts from the inside is likely to be a total pain.
I look forward to seeing the rest of your robot! |
