Re: pic: What's weird with this image
Originally Posted by Kevin Sevcik
That's a more remote possibility, but possibly true. Unless you have the exact same motors wired the exact same way, they might still turn differently. If a multimeter reads the same voltage when you put the red probe on M+ and the black probe on M-, then I would definitely agree with your assessment.
If it is bad internal LED wiring and the Talon is new, I would talk with Vex, Andymark, Cross the Road, or FIRST about getting a replacement. That LED is valuable for troubleshooting, and if all the fault codes are in flashing green, that's going to be extremely confusing.
Originally Posted by Jonathan L.
This is always backward of what the signal is. When we say forward, it turns red; When we say backward, it turns green.
Seems entirely plausible to me that the LED was simply installed backwards. Bi Color LEDs are (usually at least) 3 pin, with the center being the common Cathode, and pins 1 and 3 being the two different anodes. It would be a pretty simple mistake to install the LED 180 degrees out and have the colors reversed.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
