Go to Post Not gonna lie, I wanna marry the person over at #254 who does their wiring... I have admired it for years. :) - Lightfoot26 [more]
Unread 24-01-2016, 21:25
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: pic: 57's frame is coming along
Originally Posted by Aidan H. View Post
Just wondering (we have been working through our first year of a riveted WCD), how are you planning to run chain with those 2in tall cross members in the space between axles? Are you going to use extra large sprockets, outer chain, or individual wheel motors? Or are you dreaming up some fancy chain routing?
Also, if you are going to be running chain, are you planning on #25? We learned the hard way that it might not be strong enough for flying over defenses, flat out shattering a few links. We know "flying" over them is probably not best for any drivetrain, it'll inevitably happen a few times even if drivers are careful, but if a drivetrain can't handle that, there's going to be failures.
We've done the WCD, riveted chassis, and chain-in-tube before. With this, I'd probably just resign to putting the chains on the wheel side. Big sprockets means chain will be dragging on the defenses, which is definitely not what you want. However, with chain-in-tube, if something goes wrong, it's a nightmare to fix.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
