Go to Post An FRC team's success should not be measured in how many robots it can build or how many blue banners it can collect. It should be measured by how many engineers (and other professionals) it 'builds'. - jvriezen [more]
Unread 25-01-2016, 15:33
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: pic: 57's frame is coming along
Originally Posted by Cash4587 View Post
I would be careful using the plastic clamping bearing blocks we broke a few on the ri3d chassis going over the obstacles with speed.
Cooper, that is a fascinating insight. Like I said, this isn't our actual chassis. We're using the aluminum VersaBlocks for the outside wheels on our chassis, but we're using a plastic bearing block for the middle wheel to get the 96 tooth spacing from two simple clamping gearboxes. I'll definitely have the students abuse the chassis a bit to see if we need to do something about the plastic block for the middle wheel. If it's too fragile, I'll have to mill down a versablock to get the same spacing.
