Go to Post Free hugs are excellent things. - Eugenia Gabrielov [more]
Unread 26-01-2016, 15:06
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: pic: FRC 2869 - 2016 Shooter
Originally Posted by BryceKarlins View Post
Are the Flywheels actually mounted that high? We've found that mounting them in the exact center works best.
Just a heads up. Those aren't fly wheels.
fly·wheel
noun
a heavy revolving wheel in a machine that is used to increase the machine's momentum and thereby provide greater stability or a reserve of available power during interruptions in the delivery of power to the machine.
Unread 26-01-2016, 15:48
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
Just so I understand, the "flywheel" part of a shooter would be the extra weight added and not the actual firing wheels themselves? While these wheels are not flywheels, is it safe to say that heavy shooting wheels are technically flywheels in their own right?
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 26-01-2016, 15:56
Flywheel Police
Yeah, I guess a heavy shooter wheel would be a flywheel in itself.
Unread 28-01-2016, 11:13
Monochron's Avatar
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
You guys might need some sleep. I can't see those wheels producing a useful amount of lift at all.
Unread 28-01-2016, 11:54
Flywheel Police
Unread 27-01-2016, 17:52
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Can you please provide me with a threshold for when a spinning object is considered "heavy"?
Thanks for your time,
Orion DeYoe
FRC Team 2252 "The Mavericks" 2011-2014 (Student)
FRC Team 5413 "Stellar Robotics" 2014-???? (Mentor)
2011: Drive Coach, CAD, Programming, Electrical
2012: Drive Coach, Team Captain, Team Representative, CAD, Programming, Electrical
2013: Drive Coach, Team Captain, Team Representative, CAD, Programming, Electrical
2014: Drive Coach, Strategy, CAD
2015: Team Founder, Design/CAD Mentor, Drive Coach
Unread 27-01-2016, 22:17
When it's a flywheel.
Unread 27-01-2016, 22:22
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
A flywheel does not have to be heavy, to be able to store energy/momentum. The speed of rotation is also important as well.
Just look at Formula 1 Racing Flywheel System. They use 240 mm diameter flywheel which weighs 5 kg and spins at around 64,500 rpm. They can store enough energy to give a power boost of 60 kW for 6.67 seconds.
Unread 28-01-2016, 08:54
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I can see both sides of this argument. In general when I think of a flywheel I think of something that stores energy and/or dampens. Personally I would not consider a shooter wheel a flywheel but I have no problem with those who choose to do so.
At least it's not a piston
Unread 28-01-2016, 08:56
Yeah, I was attempting to indirectly point out that you can't say a wheel is, or isn't, a flywheel based on its weight. Because whether or not it's "heavy" just depends on how much energy you need to store.
I just wanted to emphasize the fact that the OP's terminology was correct and that these are considered flywheels in this application.
Orion DeYoe
Unread 28-01-2016, 08:59
Flywheel Police
But they're not, these wheels are not storing energy (or at least enough energy to make any difference) which is the exact point of a flywheel.
Unread 28-01-2016, 09:07
IndySam's Avatar
That's a flywheel!
Unread 28-01-2016, 09:32
Yes they are. They're storing kinetic energy. If the wheel needs to be spun up before the ball contacts it for it to work as intended, then the wheel is a flywheel. Whether or not it is a particularly good flywheel isn't relevant. Spinning wheel shooters in FRC work by storing kinetic energy, which is exactly what a flywheel is.
Unread 28-01-2016, 09:34
Electronica1's Avatar
Former Design and CAD Captain
AKA: Alexander Kaplan
FRC #1086 (Blue Cheese)
It is still a flywheel, just not a particularly good one.
Unread 29-01-2016, 19:22
viggy96 viggy96 is offline
FRC #3331
viggy96 is infamous around these partsviggy96 is infamous around these partsviggy96 is infamous around these parts
What motors are you using there in the image?
