Go to Post It is critical to our continued growth and success to recognize, and to make others realize, THERE ARE NO OPPONENTS. - Taylor [more]
Unread 27-01-2016, 17:52
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Re: pic: FRC 2869 - 2016 Shooter
Originally Posted by notmattlythgoe View Post
Just a heads up. Those aren't fly wheels.
Can you please provide me with a threshold for when a spinning object is considered "heavy"?
Thanks for your time,
Orion DeYoe
FRC Team 2252 "The Mavericks" 2011-2014 (Student)
FRC Team 5413 "Stellar Robotics" 2014-???? (Mentor)
2011: Drive Coach, CAD, Programming, Electrical
2012: Drive Coach, Team Captain, Team Representative, CAD, Programming, Electrical
2013: Drive Coach, Team Captain, Team Representative, CAD, Programming, Electrical
2014: Drive Coach, Strategy, CAD
2015: Team Founder, Design/CAD Mentor, Drive Coach
Unread 27-01-2016, 22:17
When it's a flywheel.
Unread 27-01-2016, 22:22
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
A flywheel does not have to be heavy, to be able to store energy/momentum. The speed of rotation is also important as well.
Just look at Formula 1 Racing Flywheel System. They use 240 mm diameter flywheel which weighs 5 kg and spins at around 64,500 rpm. They can store enough energy to give a power boost of 60 kW for 6.67 seconds.
Unread 28-01-2016, 08:54
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
a heavy revolving wheel in a machine that is used to increase the machine's momentum and thereby provide greater stability or a reserve of available power during interruptions in the delivery of power to the machine.
I can see both sides of this argument. In general when I think of a flywheel I think of something that stores energy and/or dampens. Personally I would not consider a shooter wheel a flywheel but I have no problem with those who choose to do so.
At least it's not a piston
Unread 28-01-2016, 08:56
Yeah, I was attempting to indirectly point out that you can't say a wheel is, or isn't, a flywheel based on its weight. Because whether or not it's "heavy" just depends on how much energy you need to store.
I just wanted to emphasize the fact that the OP's terminology was correct and that these are considered flywheels in this application.
Orion DeYoe
Unread 28-01-2016, 08:59
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
But they're not, these wheels are not storing energy (or at least enough energy to make any difference) which is the exact point of a flywheel.
Unread 28-01-2016, 09:07
IndySam's Avatar
That's a flywheel!
Unread 28-01-2016, 09:32
Yes they are. They're storing kinetic energy. If the wheel needs to be spun up before the ball contacts it for it to work as intended, then the wheel is a flywheel. Whether or not it is a particularly good flywheel isn't relevant. Spinning wheel shooters in FRC work by storing kinetic energy, which is exactly what a flywheel is.
Unread 28-01-2016, 09:34
Electronica1's Avatar
Former Design and CAD Captain
AKA: Alexander Kaplan
FRC #1086 (Blue Cheese)
It is still a flywheel, just not a particularly good one.
Unread 29-01-2016, 19:22
viggy96 viggy96 is offline
FRC #3331
viggy96 is infamous around these partsviggy96 is infamous around these partsviggy96 is infamous around these parts
What motors are you using there in the image?
Unread 29-01-2016, 19:38
pilleya's Avatar
Elec+Mech
The motors in the image are 775pro's they are a new motor available this year and are available from VEX or West Coast Products.
http://www.vexrobotics.com/vexpro/mo.../217-4347.html
http://www.wcproducts.net/motors
