Go to Post I need to start using "ThunderChickens!" as an exclamation - Jessica Boucher [more]
Unread 27-01-2016, 22:17
Re: pic: FRC 2869 - 2016 Shooter
Originally Posted by Orion.DeYoe View Post
Can you please provide me with a threshold for when a spinning object is considered "heavy"?
When it's a flywheel.
Unread 27-01-2016, 22:22
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
A flywheel does not have to be heavy, to be able to store energy/momentum. The speed of rotation is also important as well.
Just look at Formula 1 Racing Flywheel System. They use 240 mm diameter flywheel which weighs 5 kg and spins at around 64,500 rpm. They can store enough energy to give a power boost of 60 kW for 6.67 seconds.
Unread 28-01-2016, 08:54
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
a heavy revolving wheel in a machine that is used to increase the machine's momentum and thereby provide greater stability or a reserve of available power during interruptions in the delivery of power to the machine.
I can see both sides of this argument. In general when I think of a flywheel I think of something that stores energy and/or dampens. Personally I would not consider a shooter wheel a flywheel but I have no problem with those who choose to do so.
At least it's not a piston
Unread 28-01-2016, 08:56
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Yeah, I was attempting to indirectly point out that you can't say a wheel is, or isn't, a flywheel based on its weight. Because whether or not it's "heavy" just depends on how much energy you need to store.
I just wanted to emphasize the fact that the OP's terminology was correct and that these are considered flywheels in this application.
Thanks for your time,
Orion DeYoe
FRC Team 2252 "The Mavericks" 2011-2014 (Student)
FRC Team 5413 "Stellar Robotics" 2014-???? (Mentor)
2011: Drive Coach, CAD, Programming, Electrical
2012: Drive Coach, Team Captain, Team Representative, CAD, Programming, Electrical
2013: Drive Coach, Team Captain, Team Representative, CAD, Programming, Electrical
2014: Drive Coach, Strategy, CAD
2015: Team Founder, Design/CAD Mentor, Drive Coach
Unread 28-01-2016, 08:59
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
But they're not, these wheels are not storing energy (or at least enough energy to make any difference) which is the exact point of a flywheel.
Unread 28-01-2016, 09:07
IndySam's Avatar
That's a flywheel!
Unread 28-01-2016, 09:32
Yes they are. They're storing kinetic energy. If the wheel needs to be spun up before the ball contacts it for it to work as intended, then the wheel is a flywheel. Whether or not it is a particularly good flywheel isn't relevant. Spinning wheel shooters in FRC work by storing kinetic energy, which is exactly what a flywheel is.
Unread 28-01-2016, 09:34
Electronica1's Avatar
Former Design and CAD Captain
AKA: Alexander Kaplan
FRC #1086 (Blue Cheese)
It is still a flywheel, just not a particularly good one.
Unread 29-01-2016, 19:22
viggy96 viggy96 is offline
FRC #3331
viggy96 is infamous around these partsviggy96 is infamous around these partsviggy96 is infamous around these parts
What motors are you using there in the image?
Unread 29-01-2016, 19:38
pilleya's Avatar
Elec+Mech
The motors in the image are 775pro's they are a new motor available this year and are available from VEX or West Coast Products.
http://www.vexrobotics.com/vexpro/mo.../217-4347.html
http://www.wcproducts.net/motors
