Re: pic: FRC 2869 - 2016 Shooter
A flywheel does not have to be heavy, to be able to store energy/momentum. The speed of rotation is also important as well.
Just look at Formula 1 Racing Flywheel System. They use 240 mm diameter flywheel which weighs 5 kg and spins at around 64,500 rpm. They can store enough energy to give a power boost of 60 kW for 6.67 seconds. |
a heavy revolving wheel in a machine that is used to increase the machine's momentum and thereby provide greater stability or a reserve of available power during interruptions in the delivery of power to the machine.
I can see both sides of this argument. In general when I think of a flywheel I think of something that stores energy and/or dampens. Personally I would not consider a shooter wheel a flywheel but I have no problem with those who choose to do so. At least it's not a piston ![]() |
Yeah, I was attempting to indirectly point out that you can't say a wheel is, or isn't, a flywheel based on its weight. Because whether or not it's "heavy" just depends on how much energy you need to store.
I just wanted to emphasize the fact that the OP's terminology was correct and that these are considered flywheels in this application. |
That's a flywheel!
Yes they are. They're storing kinetic energy. If the wheel needs to be spun up before the ball contacts it for it to work as intended, then the wheel is a flywheel. Whether or not it is a particularly good flywheel isn't relevant. Spinning wheel shooters in FRC work by storing kinetic energy, which is exactly what a flywheel is.
It is still a flywheel, just not a particularly good one.
What motors are you using there in the image?
The motors in the image are 775pro's they are a new motor available this year and are available from VEX or West Coast Products.
http://www.vexrobotics.com/vexpro/mo.../217-4347.html http://www.wcproducts.net/motors |
