Go to Post Stratagy drives design, not features. - Wetzel [more]
Unread 27-01-2016, 22:34
cbale2000's Avatar
cbale2000 cbale2000 is online now
AKA: Chris Bale
FRC #0703 (Phoenix)
Re: pic: Battery Cart
Originally Posted by pilleya View Post
Surely the volt meter/multimeter would just display the voltage which the batteries are being charged at? That is if you are just measuring over the terminals.
But it is definitely a very neat solution
We have a similar feature on our battery cart. The volt meter does show charging voltage, but if all the batteries show the charging voltage you can still tell which one has the highest voltage. I also suspect the switches on each battery cut off the chargers allowing one to see the actual battery voltage (we thought about doing something similar to this but settled for just shutting off the power strip on the battery cart for a minute to do a quick voltage check).
