Re: pic: FRC 2869 - 2016 Shooter
Yeah, I was attempting to indirectly point out that you can't say a wheel is, or isn't, a flywheel based on its weight. Because whether or not it's "heavy" just depends on how much energy you need to store.
I just wanted to emphasize the fact that the OP's terminology was correct and that these are considered flywheels in this application. |
That's a flywheel!
Yes they are. They're storing kinetic energy. If the wheel needs to be spun up before the ball contacts it for it to work as intended, then the wheel is a flywheel. Whether or not it is a particularly good flywheel isn't relevant. Spinning wheel shooters in FRC work by storing kinetic energy, which is exactly what a flywheel is.
It is still a flywheel, just not a particularly good one.
What motors are you using there in the image?
The motors in the image are 775pro's they are a new motor available this year and are available from VEX or West Coast Products.
http://www.vexrobotics.com/vexpro/mo.../217-4347.html http://www.wcproducts.net/motors |
