Go to Post So take it all with a grain of salt, form your own opinions, lead by example, act responsibly, be graciously professional, and everything will be ok. - LauraN [more]
Unread 27-01-2016, 19:52
RoboAlum RoboAlum is offline
Mickey D's
FRC #4841 (Optimal Robotics)
RoboAlum is a jewel in the roughRoboAlum is a jewel in the roughRoboAlum is a jewel in the roughRoboAlum is a jewel in the rough
pic: Does this meet bumper rules
Unread 27-01-2016, 19:54
SenorZ's Avatar
SenorZ SenorZ is online now
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: pic: Does this meet bumper rules
That is probably not a good idea.
The free ends of the sheet metal can technically be called the frame, but are liable to get bent or just wobble a bit during a match.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 27-01-2016, 19:59
MrBasse MrBasse is online now
FRC #3572 (Wavelength)
Beyond what was said above, how long are the bent ends? They look short of 8" to me.
Andrew Basse
Unread 27-01-2016, 20:07
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
I believe that since frame perimeter is measured by a string wrapped around the robot, it doesn't matter how long the bent ends are as long as the bumper itself is 8".
Nevertheless, that looks too weak. The bumper rules aren't there to limit you; they're there to make sure the robots are safe.
Unread 27-01-2016, 20:13
EricH EricH is offline
What you believe just ran smack into R26 (minimum 1/2" at each end backed), and if you have built your bumpers per your belief, you still have time to fix them prior to bag day rather than at your first event.
I agree that it looks too weak, however. You'll want to put some backing in there. Actually, if I were you I'd try to use flanges on the next iteration--I think you could make a very similar piece that was plenty strong. Oh, and just as a note--I could see the pictured configuration rapidly ending up rubbing a wheel. Make it stronger, and bring it closer (if you need to in order to make frame perimeter length).
Unread 27-01-2016, 20:26
Mickey D's
we're thinking of just making it out of 1x1 and going out past the wheel and making an L shape and mounting to the top of the 1" on the inside of the tires
Co-Founder and Director
RASA (Robotics.Alliance.of Southern Arizona) 501c3
FRC 4841 2013-
VEX 4874 2013-
Student
FRC 71 2010-2013
Unread 27-01-2016, 20:34
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by R2
The ROBOT must have a FRAME PERIMETER, contained within the BUMPER ZONE, that is comprised of fixed, non-articulated structural elements of the ROBOT. Minor protrusions no greater than ¼ in. such as bolt heads, fastener ends, and rivets are not considered part of the FRAME PERIMETER.
SO far, it's definitely legal.
Originally Posted by R21 G.
Bumpers..must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form a tight, robust connection to the main structure/frame (e.g. not attached with hook-and-loop, tape, or tie-wraps). The attachment system must be designed to withstand vigorous game play. All removable fasteners (e.g. bolts, locking pins, pip-pins, etc.) will be considered part of the BUMPERS.
No matter how robust the connection between the frame perimeter and the bumpers, were I an inspector, I would rule that this does not constitute a robust connection to the main structure/frame.
For the record, I am not an inspector.
Edit: Especially on the corners,which is where bumpers are mandatory.
Unread 27-01-2016, 20:44
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Even if it is legal my question is are you okay running it into something like a stop sign?
Don't look at the rules being "legal" or not look at them being as minimums for safety and if you want to be "off" make the off lean towards safer.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 28-01-2016, 02:04
AKA: Thomas
Looks like I have to give the manual another read-through. Thanks for the warning.
Unread 28-01-2016, 09:17
This isn't a bumper attachment system, though. This is the frame of their robot. The rules do not require the robot's frame be rigid or strong. This seems like a legal way to define the frame perimeter of the robot.
Now, clearly in a practical sense this is not a very robust system as it stands, and the bent pieces of metal will likely want some support behind them in order for this to be part of a successful robot frame that doesn't immediately crumple to pieces upon impact. But it doesn't seem like it isn't legal.
Unread 28-01-2016, 09:27
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
+1
Legal and wise are 2 different words.
With some boxing and gussets this could work fine.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 28-01-2016, 09:40
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
It amazes me... we take one season off from bumpers and now everyone wants to cop-out OP, if you just redo those pieces so they have flanges, then run some 1x1 tube from your chassis out to the sheet metal, you'll be golden. The robot rules are there for the safety of the robots and those around them, not as constraints on your design possibilities.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 28-01-2016, 10:40
rich2202 rich2202 is online now
FRC #2202 (BEAST Robotics)
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
One of the benefit of the Bumpers is that they protect your robot. If you want to design a crumple zone, that is your call. But, that will require you to be able to repair the robot quickly between matches (from COTS parts if you don't want them to count against your Hold Back). Also, in the process of crumpling, it could damage other stuff in your robot.
Also, consider R2 where:
R2 The ROBOT must have a FRAME PERIMETER, contained within the BUMPER ZONE, that is comprised of fixed, non-articulated structural elements of the ROBOT.
and R23:
R23 BUMPERS must not be articulated (relative to the FRAME PERIMETER).
You might want to think about whether the design would have your Bumpers be "fixed" to the Frame Perimeter in normal game play.
In other words: The crumpling of the Frame is not against the rules. However, the crumpling of the Frame does not cause a change in the Frame Perimeter. If the Frame crumples, and an attached Bumper moves with it, then the Bumper has moved with respect to the Frame Perimeter, and could be a violation of R23.
Unread 28-01-2016, 10:41
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
Chassis, robot, floor, coffee stain, ... I didn't have my coffee this morning, need to find coffee machine.
Does anyone knows what I was going to post?
Unread 29-01-2016, 02:23
dtengineering's Avatar
AKA: Jason Brett
I'd note the "non-articulated" term used to describe the frame perimeter. "Articulated: having two or more sections connected by a flexible joint" pretty much describes those end pieces of sheet metal. I know others have mentioned them as weak, floppy and unwise from a practical viewpoint, but in my take on it, I would also include them as "illegal" as they are articulated due to the flexible nature of the corner joint.
Anyway, sounds like you are on top of it... good idea to post here and ask for advice.
Jason
