Go to Post I love the smell of a upcoming FRC build season in the morning. The sleepless night; the drills; welding; cutting of metal. I wait all yr. for this. - midway78224 [more]
Unread 28-01-2016, 18:45
prozack19's Avatar
prozack19 prozack19 is offline
AKA: Zackary Peery
FRC #0056 (R.O.B.B.E.)
prozack19 has a brilliant futureprozack19 has a brilliant futureprozack19 has a brilliant futureprozack19 has a brilliant futureprozack19 has a brilliant futureprozack19 has a brilliant futureprozack19 has a brilliant futureprozack19 has a brilliant futureprozack19 has a brilliant futureprozack19 has a brilliant futureprozack19 has a brilliant future
Send a message via MSN to prozack19
Re: pic: Battery Cart
Originally Posted by cbale2000 View Post
We have a similar feature on our battery cart. The volt meter does show charging voltage, but if all the batteries show the charging voltage you can still tell which one has the highest voltage. I also suspect the switches on each battery cut off the chargers allowing one to see the actual battery voltage (we thought about doing something similar to this but settled for just shutting off the power strip on the battery cart for a minute to do a quick voltage check).
Yes when we flip the switch the battery stops charging and we can read the actual voltage.
FRC 869
2013-web design
2014- lead scout/strategist
2015- lead scout/strategist, hp, chairmans presenter
2016- lead scout/strategist
FRC 56 2016- present
scouting and strategy mentor
