Thread Tools |
Rating:
Display Modes |
Re: pic: Are these legal?
Nitpick: actually such a laptop would be legal if it were powered off a DC-DC converter and the battery removed as it is a COTS computing device. Obviously overkill, but perfectly legal by itself.
The battery can stay if it's integral to the device.
In part it reads: "Additionally, batteries integral to and part of a COTS computing device or self-contained camera are also permitted (e.g. laptop batteries, GoPro style camera, etc.)," As to modifying the SB50/120 connectors, the intent of R66 is to prevent teams from modifying electrical items in such a way that would cause a safety issue. Removing anything from a high current electrical connector may affect the safe use of such an item. R9 is also a little more pertinent to this question. The SB connectors are tested by UL for specified current and voltage without parts removed. |
What about just painting the connector? Blue, purple, green, whatever if that is important to you?
I think R66 would apply and make painting the connector illegal. At least that is my take on the rules.
I don't see an issue with modifying the connector to mate with another connector. This isn't reducing it's protection from a short or its current carrying capacity of the connector itself. It's like saying a car isn't safe in a crash because you took the dice off the mirror. They aren't integral to the function of the device. |
Somebody correct me if I'm wrong, but I could have sworn it was legal to make an adapter that goes from, say, a red SB50 to a SB100 and have it be part of your robot. Could the same thing work for blue to red SB50s, or am I mistaken?
The intent of R66 is to prevent the intentional modification of electrical components to maintain some reasonable level of safety. I am all for innovation, but there are some guidelines and rules we all need to stay within. Plus, if you make it to the finals and you need to borrow a 'spare parts' battery, it will have a SB50. You won't be able to connect. |
"The SB50 connector series is keyed by color."
"Plus, if you make it to the finals and you need to borrow a 'spare parts' battery, it will have a SB50. You won't be able to connect." It will be either a black or gray connector and it won't fit the blue one. This would be the biggest reason to not use the blue connector. The color keyed SB50's is a nice feature if you know you'll never need to mate with a different color. We did a project with them, color coded cause it was cool and then got burned when we couldn't swap around. Decided to make "color adapters" and then decided to go black/gray all around with a strip of colored tape on the connector and cable. |
