Go to Post If they had kids, they would be a super-breed of robot builders and drivers, and would win dozens of awards per season. - smurfgirl [more]
Unread 01-02-2016, 01:48
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: pic: 2929's Forklift + Climber, almost operational
Originally Posted by JohnFogarty View Post
I hope you've done the math on the volume of air those cylinders you've chosen will need to extend and then retract.
Did this early on.
As it happens, if you use 1.5''-bore, 2'-stroke cylinders and run them out at 30PSI and in at 60PSI, you're more than covered with two black clippard tanks.
"The breakfast of champions!"
