Go to Post and don't overestimate the ability of an unskilled fool with exotic tools! - MissInformation [more]
Unread 01-02-2016, 02:43
FRC #1836 (MilkenKnights)
Re: pic: 2929's Forklift + Climber, almost operational
Originally Posted by Oblarg View Post
Did this early on.
As it happens, if you use 1.5''-bore, 2'-stroke cylinders and run them out at 30PSI and in at 60PSI, you're more than covered with two black clippard tanks.
PSI drops as you use your tanks. So at some point you won't get quite the full force of your actuators.
