Go to Post Is this where I get to say "Mama I made it on TV?" - Pauline Tasci [more]
Unread 01-02-2016, 07:33
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Re: pic: Are these legal?
Originally Posted by ratdude747 View Post
Nitpick: actually such a laptop would be legal if it were powered off a DC-DC converter and the battery removed as it is a COTS computing device. Obviously overkill, but perfectly legal by itself.
Please see R31...
In part it reads:
"Additionally, batteries integral to and part of a COTS computing device or self-contained camera are also permitted (e.g. laptop batteries, GoPro style camera, etc.),"
As to modifying the SB50/120 connectors, the intent of R66 is to prevent teams from modifying electrical items in such a way that would cause a safety issue. Removing anything from a high current electrical connector may affect the safe use of such an item. R9 is also a little more pertinent to this question. The SB connectors are tested by UL for specified current and voltage without parts removed.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 01-02-2016, 12:28
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
What about just painting the connector? Blue, purple, green, whatever if that is important to you?
success is not hocus posus, it's focus focus
Unread 01-02-2016, 12:42
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
I think R66 would apply and make painting the connector illegal. At least that is my take on the rules.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 01-02-2016, 20:43
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
R66 says nothing about the wires or connectors attached to the battery. It says you can't change or modify the battery (among other things).
I don't see an issue with modifying the connector to mate with another connector. This isn't reducing it's protection from a short or its current carrying capacity of the connector itself. It's like saying a car isn't safe in a crash because you took the dice off the mirror. They aren't integral to the function of the device.
Andrew Basse
Unread 01-02-2016, 21:06
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Somebody correct me if I'm wrong, but I could have sworn it was legal to make an adapter that goes from, say, a red SB50 to a SB100 and have it be part of your robot. Could the same thing work for blue to red SB50s, or am I mistaken?
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 02-02-2016, 07:42
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Originally Posted by Al Skierkiewicz View Post
Please see R31...
In part it reads:
And I'm sure they are tested without being painted or modified on the external surfaces of the connector as well. What's to prevent a team from wrapping a 1 1/2 inches of Viton around the connectors and 4 inches down the wire? Is that legal? My thought process tells me it is acting as insulting device and not allowing heat to be dissipated and possibly causing a meltdown.
The intent of R66 is to prevent the intentional modification of electrical components to maintain some reasonable level of safety. I am all for innovation, but there are some guidelines and rules we all need to stay within.
Plus, if you make it to the finals and you need to borrow a 'spare parts' battery, it will have a SB50. You won't be able to connect.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 02-02-2016, 08:01
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
"The SB50 connector series is keyed by color."
"Plus, if you make it to the finals and you need to borrow a 'spare parts' battery, it will have a SB50. You won't be able to connect."
It will be either a black or gray connector and it won't fit the blue one. This would be the biggest reason to not use the blue connector.
The color keyed SB50's is a nice feature if you know you'll never need to mate with a different color. We did a project with them, color coded cause it was cool and then got burned when we couldn't swap around. Decided to make "color adapters" and then decided to go black/gray all around with a strip of colored tape on the connector and cable.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
