Go to Post Progress should never made at the expense of the past. - Koko Ed [more]
Unread 02-02-2016, 07:42
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Re: pic: Are these legal?
Originally Posted by Al Skierkiewicz View Post
Please see R31...
In part it reads:
"Additionally, batteries integral to and part of a COTS computing device or self-contained camera are also permitted (e.g. laptop batteries, GoPro style camera, etc.),"
As to modifying the SB50/120 connectors, the intent of R66 is to prevent teams from modifying electrical items in such a way that would cause a safety issue. Removing anything from a high current electrical connector may affect the safe use of such an item. R9 is also a little more pertinent to this question. The SB connectors are tested by UL for specified current and voltage without parts removed.
And I'm sure they are tested without being painted or modified on the external surfaces of the connector as well. What's to prevent a team from wrapping a 1 1/2 inches of Viton around the connectors and 4 inches down the wire? Is that legal? My thought process tells me it is acting as insulting device and not allowing heat to be dissipated and possibly causing a meltdown.
The intent of R66 is to prevent the intentional modification of electrical components to maintain some reasonable level of safety. I am all for innovation, but there are some guidelines and rules we all need to stay within.
Plus, if you make it to the finals and you need to borrow a 'spare parts' battery, it will have a SB50. You won't be able to connect.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 02-02-2016, 08:01
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
"The SB50 connector series is keyed by color."
"Plus, if you make it to the finals and you need to borrow a 'spare parts' battery, it will have a SB50. You won't be able to connect."
It will be either a black or gray connector and it won't fit the blue one. This would be the biggest reason to not use the blue connector.
The color keyed SB50's is a nice feature if you know you'll never need to mate with a different color. We did a project with them, color coded cause it was cool and then got burned when we couldn't swap around. Decided to make "color adapters" and then decided to go black/gray all around with a strip of colored tape on the connector and cable.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
