Go to Post Look at the success of the Banebot's gearboxes this year. Cheap, light, small, and a lot of people are using them, even though their quality may be a bit questionable... Make a similar gearbox for a drivetrain (with a bit more robustness) and I think you've got a winner. - Ben Piecuch [more]
Unread 02-02-2016, 20:16
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
pic: Team 2053 Standard
Unread 02-02-2016, 20:17
RoboChair's Avatar
AKA: Devin Castellucci
Re: pic: Team 2053 Standard
I don't think that this conforms to the rules laid out for team standards.
http://www.firstinspires.org/sites/d...ifications.pdf
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 02-02-2016, 20:24
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
Are you concerned about this rule?
The horizontal support piece(s) length may not exceed 15” (762mm) in length and ½” (12.5mm) OD.
Unread 02-02-2016, 20:29
RoboChair's Avatar
Primarily, yes.
Unread 02-02-2016, 22:08
Bob Steele's Avatar
On the RIBMEATS bandwagon....
AKA: Bob Steele
I really like your design.... very creative and plenty strong.
I do think that there may be a couple of issues with it.
If you win a ribbon how will you attach it?
The ribbons have grommets that will fit over 1/2" material. I believe the horizontal piece is supposed to reserve 1.5 inches at the end for them. If your frame comes apart I suppose you could put them in between the pipe frame and the standard. I do think the intention of the rule is that they would be able to fly on the outside.
I am not sure how the rules interpret the "standard"
I think there is a horizontal piece not to exceed 15" and a vertical piece not to exceed 32".
I would imagine that everything else is the standard itself
The rule states: The Standard substrate must be made of cloth or other flexible material.
The pipe frame you have is not cloth or other flexible material.
I am not trying to criticize I just think you should check and see. It would be a shame to get to an event and find out that your really cool standard could not be flown.
Again... very cool job.. I would not have thought to do a pipe frame like that
