Go to Post Nutritionally speaking I didn't get enough (MOE) green in my FIRST diet this year! - Mark McLeod [more]
Unread 04-02-2016, 23:06
tjustic3 tjustic3 is offline
FRC #4576
tjustic3 is an unknown quantity at this point
pic: 4576 RNR CAD Angle 2
Unread 04-02-2016, 23:07
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Re: pic: 4576 RNR CAD Angle 2
Will all that actually be carbon fiber, or is that just for the cool visual?
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 04-02-2016, 23:21
cxcad cxcad is offline
FRC #1683 (Techno Titans)
Do I spy a pto? Or is that an interesting gearbox?
Unread 05-02-2016, 01:28
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
How do you plan to go over the rock wall? It looks like you're using 8'' pneumatic wheels, so the frame would have about 3'' of ground clearance. Right now, your drivetrain frame would hit the rock wall before the wheels do. Am I missing some other mechanism?
Unread 05-02-2016, 01:56
Aaron Ng's Avatar
Aaron Ng Aaron Ng is offline
Aaron Ng is on a distinguished road
there is a cutout in the front. looks like 1in. Along with the tilt given from the ramp, looks like it would be easy to go over the rock wall.
I cant really judge the height of the robot because of the odd angles, but it looks like it is around 16in. to go under the low bar, the robot (at least the fount and back) has to be well below 16in because of the tilting that the robot will face driving up and down the ramp. for my team, we have set 14in to be the max height any part of the robot.
Unread 05-02-2016, 05:14
FRC #4576
Yes, all this is currently carbon fiber.
Unread 05-02-2016, 05:20
FRC #4576
The gear box has two pulleys and a belt integrated into it allowing two output shafts. We did this to have a 6 wheel drive. We have two belts in the tubing. One goes from output a to the back, and output a drives center wheel. Then output b goes forward to run front wheel, and output b is terminated in the channel. This allows two 15mm belts to run on the same plane. In doing so we were able to keep all our belts inside the tubing. And it has a dog gear to allowing two speeds just like vexpro gearboxes are ran.
Unread 05-02-2016, 05:25
FRC #4576
You are correct with the 3" ground clearance. We also do have a shorter front. Allowing it to go over the rock wall with ease. Because the front wheel grabs prior to the channel hitting the rock wall face.
Unread 05-02-2016, 05:26
FRC #4576
The whole robot assembly is currently sitting at 14.125 inches tall allowing easy clearance all the way around.
