Go to Post With all that chain call it Link and dress it up like Zelda. - nuggetsyl [more]
Unread 04-02-2016, 23:46
ImMoMo's Avatar
ImMoMo ImMoMo is offline
AKA: Mo
FRC #2559 (Normality Zero)
ImMoMo is an unknown quantity at this point
pic: 2559 Normality Zero 2016 Drive Train v1
Unread 04-02-2016, 23:47
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
Re: pic: 2559 Normality Zero 2016 Drive Train v1
Like it, but my gut says that you should be better cross bracing. Right now that middle link acts as a two force member that can only transmit tension/compression, not bending or shearing forces.
Unread 04-02-2016, 23:48
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
I'd be weary of damaging the internals of the battery with its flat position, especially with the high shock nature of this game around the outer works. Is this an issue that was considered in the design and is there a way you're going to prevent any battery damage?
Unread 04-02-2016, 23:56
I've never heard of this being an issue before. Hundreds of teams have run batteries flat in the robot for years without issue. There are even COTS products available to assist in teams securing batteries laid flat on the chassis. What components of the battery do you suspect would be more suceptible to damage in this orientation?
In any case, the battery in this photo is clearly very well secured, with structure on all sides of it and a tight strap across the open side.
Unread 05-02-2016, 00:17
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Can't really see the front of the robot too well, but I trust you're obeying R19 and R26?
Unread 05-02-2016, 00:20
bEdhEd's Avatar
Since my rookie year, I've been indoctrinated to avoid flat battery placement for the sake of reducing risk of plate cracking. We've put batteries flat before too, but that was for off season robots meant for smooth surface driving. Maybe it's just my team that thinks this. This game may have a few more high-flying bumps than previous games, and it's why I bring this up. Otherwise, I wouldn't have. Perhaps this kind of jarring movement would put any batteries at risk regardless of orientation.
Unread 05-02-2016, 00:43
Certified Nerd's Avatar
Certified Nerd Certified Nerd is offline
The Only Certified Nerd! GOT IT?!
AKA: Danny
FRC #3840 (TNT)
Certified Nerd is an unknown quantity at this point
All I can see is your pile of 9 fluke multimeters.
Unread 05-02-2016, 00:53
ImMoMo's Avatar
AKA: Mo
Haha, our school is a career/vocational school, so those fluke meters actually are property of the school, however, our robotics team is allowed to use them.
While the bumpers are not currently on the frame, we will be able to abide by those rules.
The mounting and positioning of the battery on this chassis are not finalized, this current configuration was just for prototyping purposes. The battery will not be mounted in the back for weight distribution purposes. You bring up a very good point regarding the "shock" this game will have, we have realized this already, and will most likely place the battery elsewhere.
There will be more cross/bracing support once the other mechanical mechanisms have been mounted.. however, from our testing, this frame seems to be very sturdy!
Unread 05-02-2016, 08:43
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #1736 (Robot Casserole)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
What robot speed are you geared with the toughboxes? Looks like direct drive and 8in wheels which others have mentioned they had turning issues.
Unread 05-02-2016, 08:49
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is online now
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Those wheels are spaced pretty far apart. Do you guys bottom out when crossing the Rock Wall or Moat?
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2017: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
