Go to Post I hope Dave doesn't see these. He'll want you to put in a banana and use it for a game clue. - IndySam [more]
Unread 05-02-2016, 05:20
tjustic3 tjustic3 is offline
FRC #4576
tjustic3 is an unknown quantity at this point
Re: pic: 4576 RNR CAD Angle 2
Originally Posted by cxcad View Post
Do I spy a pto? Or is that an interesting gearbox?
The gear box has two pulleys and a belt integrated into it allowing two output shafts. We did this to have a 6 wheel drive. We have two belts in the tubing. One goes from output a to the back, and output a drives center wheel. Then output b goes forward to run front wheel, and output b is terminated in the channel. This allows two 15mm belts to run on the same plane. In doing so we were able to keep all our belts inside the tubing. And it has a dog gear to allowing two speeds just like vexpro gearboxes are ran.
