Go to Post In most cases on FIRST robots, we have more material than in we need in some places and less than we need in others. That single phenomenon is the leading cause of robot failures. - Paul Copioli [more]
Unread 02-05-2016, 01:20 PM
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
Re: pic: Rhino Drive Train
Originally Posted by nlt5 View Post
Quick question. Will the front where the cut out is comply with the bumper rules. I interpreted the rules to mean that you have to have a minimum of 8 in covered and supported on each edge of the frame perimeter. Is each side of your cut out less than 8 in? it looks great by the way well done.
Thanks!
Ok so a couple of things. We ended up drilling out the rivets on the outside plates and replacing them with screws to facilitate replacing belts. This can now be done relatively quickly provided we can actually buy belts when they come back in stock.
Second, about the front bumper supports. They are 8 inches wide. :-)
Thanks for all of the help with this! Your feed back is helping us build a better robot.
Edoga
