Go to Post I knew that the students on our team really understood what FIRST was all about when, two years later, our unofficial team motto changed from "we want to BEAT Chief Delphi" to "we want to BE Chief Delphi." - dlavery [more]
Unread 05-02-2016, 15:24
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
Re: pic: Custom encoder mount for Mini CIM/CIM
Originally Posted by Peyton Yeung View Post
Does that still leave you much space for pinion gear mounting inside a gear box? Very similar to this one.
I'm not sure, it might not work for some pinion to gearbox applications, but it works well for an 8mm inside diameter keyed shaft (or equivalent shaft adapter).
I hadn't seen the one in the link before! Here I thought we had a novel idea!
