Go to Post One transmission to rule them all, one transmission to bind them... :p - artdutra04 [more]
Unread 06-02-2016, 21:11
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Re: pic: 4576 RNR CAD
Originally Posted by tjustic3 View Post
We have done the math and we can put 5 black clippard accumulator tanks at 100psi and we will be perfectly fine to run the piston both in and out without needing any air. We also have an air compressor filling the accumulators on the bot.
I just checked your math at 120psi, and it looks like you're good for exactly one pop- make sure you don't miss the bar! At that point, is there even a reason to use an compressor, though? You won't rebuild air nearly fast enough to be able to get enough pressure for a second actuation, and you can drop some weight if you don't have it on-board.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
