Go to Post Its not how much knowledge you have, its how much you want to learn. - tennispro9911 [more]
Unread 07-02-2016, 23:27
Bluman56's Avatar
Bluman56 Bluman56 is offline
Mentor Without Borders
AKA: Nikita
FRC #2579
Bluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the rough
Re: pic: Bottom View 1188 2016 Bot
What is the purpose of the omnis on the intake?
Unread 07-02-2016, 23:37
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Are the gearboxes actually going to be mounted there? I recall testing an old drivetrain model using 8in pneumatic wheels and WCP DS gearbox. I placed it on the ramparts, and it seemed like the gearboxes are going to hit the ramparts.
So if you guys are really mounting the gearboxes there, then expect some damages. Is it possible to mount more high up, and chain downwards?
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
Unread 08-02-2016, 08:27
Chris Mounts's Avatar
Chris Mounts Chris Mounts is offline
FRC #1188 (Oaktown Crewz)
Chris Mounts is an unknown quantity at this point
Omins are to smooth out rolling up and down ramps. They may or may not make it to the final competition bot.
The gearboxes are really that low. For most of the defenses that should be fine. I was actually more worried about the rough terrain. I didn't think the ramparts would catch. We'll check. Maybe add a ABS skid plate.
Unread 08-02-2016, 09:28
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
I'm assuming the two small protrusions are for the Portcullis? Wouldn't it hit the top intake roller as you you went under?
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 08-02-2016, 10:12
The protrusions are for the Portcullis. Our hope is that we're actually able to lift the Portcullis by running the intake in reverse with some traction material on the outside edges. The concern is that there is a dramatic difference between our plywood Portcullis and the real field elements. With no way to test we need a plan B.
