Re: pic: Team 1305's second robot.
You guys aren't wrong. It is 14 powered wheel drive using 4" wheels. We choose this design to try and disable the defences as well AS a track without having the extra difficuly and breakability. And our choice has been very good.
The intake arm clears the bumpers by ~ 1/4". It is very close. There is very little space anyways on this robot. We choose to colon performa wheels for their durability and robustness. We didn't choose pneumatic tire for 2 main reasons; cost (30+dollars per wheel), and the reduced driving capability when not crossing a defence. Last edited by Median240 : 09-02-2016 at 03:12. |
What's the weight as pictured?
Looks good. I like the Intake deployment style. What constraints led to that choice, instead of an intake that folds out? -Nick |
-Nick[/quote] The biggest factor that led us to this design was space. To get the amount of reach we wanted with a fold out designated would Nyerere wit our shooter wheels. |
I should have purchased stock in Colson.
Nice robot! That shooter looks really similar to ours. What angle does the ball leave at? How's your consistency been?
It looks at first glance more like a printing press or copier with the cover removed than an FRC robot. Not a bad thing, just curious. Definitely a clean, consistent look.
Are there three belts connecting the front roller shaft with the middle one, or are there interruptions in one or both of those shafts? |
That didn't answer my question. Is there only one forward shaft, and only one middle shaft (what I guess you're calling rearguard), or are those shafts interrupted somewhere between the obvious bearing plates? If they are both solid shafts, why three belts? If they are interrupted, why were they interrupted?
What about bumpers? Does your intake come in?
#10
Yes. It slides on rails in and out. When in the close position the front of the intake is fully inside the frame. If you look closely at the plates which hold the intake you can kind of see the sliders.
#11
And where I said rearguard I meant rearward or the middle shaft. Hopefully this answers your questions. |
#12
Yes, thanks. The angle is rather extreme; I did not see that the belts were centered over the intake area. Now that I'm looking for it, it's almost obvious.
#13
When we get it fully built I plan to put a few videos of it in action up, so that might clear up anything else.
