Go to Post If this was really about changing the culture, FIRST would be on Will.I.Am's website. - Meredith Novak [more]
Unread 09-02-2016, 07:30
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: pic: Team 1305's second robot.
What's the weight as pictured?
Looks good. I like the Intake deployment style. What constraints led to that choice, instead of an intake that folds out?
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 09-02-2016, 07:39
Median240's Avatar
Median240 Median240 is offline
AKA: Hayden
FRC #1305 (Ice Cubed)
Median240 is on a distinguished road
-Nick[/quote]
The biggest factor that led us to this design was space. To get the amount of reach we wanted with a fold out designated would Nyerere wit our shooter wheels.
Unread 09-02-2016, 13:37
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I should have purchased stock in Colson.
Unread 09-02-2016, 17:42
Jcarbon Jcarbon is online now
FRC #3322 (Eagle Imperium)
Jcarbon has a spectacular aura aboutJcarbon has a spectacular aura about
Nice robot! That shooter looks really similar to ours. What angle does the ball leave at? How's your consistency been?
Unread 09-02-2016, 18:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
It looks at first glance more like a printing press or copier with the cover removed than an FRC robot. Not a bad thing, just curious. Definitely a clean, consistent look.
Are there three belts connecting the front roller shaft with the middle one, or are there interruptions in one or both of those shafts?
Unread 09-02-2016, 22:19
Median240's Avatar
AKA: Hayden
No. They connect to the rearguard shaft to drive the wheels on it.
Unread 09-02-2016, 23:19
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
That didn't answer my question. Is there only one forward shaft, and only one middle shaft (what I guess you're calling rearguard), or are those shafts interrupted somewhere between the obvious bearing plates? If they are both solid shafts, why three belts? If they are interrupted, why were they interrupted?
Unread 10-02-2016, 00:42
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
PowerfulKitty will become famous soon enough
What about bumpers? Does your intake come in?
Unread 10-02-2016, 07:00
Median240's Avatar
AKA: Hayden
Yes. It slides on rails in and out. When in the close position the front of the intake is fully inside the frame. If you look closely at the plates which hold the intake you can kind of see the sliders.
Unread 10-02-2016, 06:58
Median240's Avatar
AKA: Hayden
OK I misunderstood you question the first time. Yes there is on forward shaft and on middle shaft. Neither r of These are interested, and the reason for the 3 belts is to guide the ball to the middle set of rollers. This was done because on tended to make the ball intake more off centre. The middle roller is there to bring to ball into the robot.
And where I said rearguard I meant rearward or the middle shaft.
Hopefully this answers your questions.
Unread 10-02-2016, 08:17
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Yes, thanks. The angle is rather extreme; I did not see that the belts were centered over the intake area. Now that I'm looking for it, it's almost obvious.
Unread 10-02-2016, 16:05
Median240's Avatar
AKA: Hayden
When we get it fully built I plan to put a few videos of it in action up, so that might clear up anything else.
