Re: pic: MVRT's robot plan (95% done)
What are you using to rotate your shooting mechanism back into your robot?
There also appears to be a disc there. Possibly for a bike style pneumatic disk break? |
That is one polished boulder!
I think I see the hooks for your scaling mechanism, are they supposed to be positioned where they are or are they supposed to be attached to the arms? Are you using a pulley lift or spring lift for the arm? |
How are you guys planning on opening the Portcullis?
Also how do you guys plan on keeping your compressor held down on your robot? Alot of terrain defenses could make having a conpressor a hazard. Anyways looks great! |
Awesome CAD model
Where will you be mounting your battery, main breaker and motor controllers? I would suggest you get the generic electrical schematic drawing and "follow the power flow" from the battery through the main breaker, PDP, motor controllers to the motors and lay out your components that way. Allow at least 1 inch around all sides of the main electrical components (RoboRio, PDP, PCM, VRM) for routing your wiring.
In your current design, the wires coming out of one side of your PDP will catch on one of the cylinders for your climbing mechanism. You will also have trouble getting the tool into the Wago's on that side. On the other side, the wires coming out of your PDP will have to run over the router. This will make it difficult and messy to remove your router for programming at each tournament you go to. Can you use the empty space between your current electronics panel and the boulder collector mechanism or is that space reserved for future enhancements? |
Thank you for the compliments and suggestions!
We were planning on just using woodscrews or machine screws + threaded inserts to hold down the compressor. Quote:
We are using constant-force springs to extend the elevator/arm, and a pneumatic cylinder to flip it upright. A winch serves to retract it. Quote:
Thank you for the notes on the PDP placement, I did not think about the router issue. I was planning on just rotating it so it doesn't hit... I just redid the electronics placement. Rest assured we have enough space for everything, but we have to place the motor controllers in the front of the robot. |
