Re: pic: Team 1305's second robot.
I should have purchased stock in Colson.
Nice robot! That shooter looks really similar to ours. What angle does the ball leave at? How's your consistency been?
It looks at first glance more like a printing press or copier with the cover removed than an FRC robot. Not a bad thing, just curious. Definitely a clean, consistent look.
Are there three belts connecting the front roller shaft with the middle one, or are there interruptions in one or both of those shafts? |
That didn't answer my question. Is there only one forward shaft, and only one middle shaft (what I guess you're calling rearguard), or are those shafts interrupted somewhere between the obvious bearing plates? If they are both solid shafts, why three belts? If they are interrupted, why were they interrupted?
What about bumpers? Does your intake come in?
Yes. It slides on rails in and out. When in the close position the front of the intake is fully inside the frame. If you look closely at the plates which hold the intake you can kind of see the sliders.
And where I said rearguard I meant rearward or the middle shaft. Hopefully this answers your questions. |
Yes, thanks. The angle is rather extreme; I did not see that the belts were centered over the intake area. Now that I'm looking for it, it's almost obvious.
#10
When we get it fully built I plan to put a few videos of it in action up, so that might clear up anything else.
