Go to Post The problem with random numbers is you never know. - GregT [more]
Unread 09-02-2016, 23:19
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Team 1305's second robot.
Originally Posted by Median240 View Post
No. They connect to the rearguard shaft to drive the wheels on it.
That didn't answer my question. Is there only one forward shaft, and only one middle shaft (what I guess you're calling rearguard), or are those shafts interrupted somewhere between the obvious bearing plates? If they are both solid shafts, why three belts? If they are interrupted, why were they interrupted?
Unread 10-02-2016, 00:42
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
PowerfulKitty will become famous soon enough
What about bumpers? Does your intake come in?
Unread 10-02-2016, 07:00
Median240's Avatar
Median240 Median240 is offline
AKA: Hayden
FRC #1305 (Ice Cubed)
Median240 is on a distinguished road
Yes. It slides on rails in and out. When in the close position the front of the intake is fully inside the frame. If you look closely at the plates which hold the intake you can kind of see the sliders.
Unread 10-02-2016, 06:58
Median240's Avatar
AKA: Hayden
OK I misunderstood you question the first time. Yes there is on forward shaft and on middle shaft. Neither r of These are interested, and the reason for the 3 belts is to guide the ball to the middle set of rollers. This was done because on tended to make the ball intake more off centre. The middle roller is there to bring to ball into the robot.
And where I said rearguard I meant rearward or the middle shaft.
Hopefully this answers your questions.
Unread 10-02-2016, 08:17
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Yes, thanks. The angle is rather extreme; I did not see that the belts were centered over the intake area. Now that I'm looking for it, it's almost obvious.
Unread 10-02-2016, 16:05
Median240's Avatar
AKA: Hayden
When we get it fully built I plan to put a few videos of it in action up, so that might clear up anything else.
