Go to Post I then asked if I could use a flux capacitor for power, but that didn't go over too well, either (they did say I could use it for decorative purposes, though). - Kevin Watson [more]
Unread 10-02-2016, 19:32
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
Re: pic: Custom encoder mount for Mini CIM/CIM
We ran the encoder class on the encoder with the resolution set to 256. We got roughly 25,000 from the encoder class. 25,000ticks x (60sec/min) / (256ticks/rev) = about 5,859 RPMs. Since this was a full speed minicim I'd say the data was valid and I'd say the encoder's resolution is based on rising (or falling) edge and not both. Otherwise the RPM data would not be right.
The beauty of this encoder is that we can set the resolution lower if there was a sampling rate issue, simply with dip switches.
