Go to Post Even when the system is "really good" it can always be tweaked a little to make it even better. - dlavery [more]
Unread 14-02-2016, 18:21
kmodos kmodos is offline
AKA: Alex
FRC #1126 (SparX)
kmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to behold
Re: pic: #TeamTablet
Answering as many questions as I can with this post:
- The 6 identical tablets are the $50 Kindle Fire HD 7in, running CM 12.1. The other two are some sort of refurb lenovos we bought last year.
- We have an inverter that takes the 12v robot batteries and converts it to 120v AC to charge the tablets if we have no access to an outlet.
- There is an Anker 10 port usb charger, so that we only need one outlet at a time.
- We are running a custom scouting app.
Should be all of the questions. If you have more, feel free to ask.
Unread 15-02-2016, 11:16
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
Very cool, thanks for the rundown.
Unread 15-02-2016, 16:45
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
We have a very similar setup this year. How are you handling the process of data? Are you sending the data from the scouts to a "master" tablet? Are you posting/syncing to the cloud at all?
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 15-02-2016, 17:14
AKA: Alex
FRC #1126 (SparX)
It is stored locally to a SQL server and then pushed to a GAE NDB server when internet is available. The tablets can also retrieve from this server to get up-to date info on both our alliance partners and opponents. We also use the GAE bulkloader to get info into a .csv that we can analyze in either Tableau or Excel
