Re: What speed is your Boulder launching at
We're somewhere in the range of ludicrous speed to bench grinder.
2.1 bench grinders. (Spell correct just tried to change grinders to gingers. Silly spellcheck. Gingers aren't a measure of speed). |
We launch ours at 88mph during qualification rounds so that they'll move forward in time and all get scored simultaneously in the finals.
If we shot the boulder through a Chronograph it would be around "Do we really need this much speed and force?" feet per second. It's enough to help a five-ounce bird carry a one pound coconut.
enough
Well, the surface speeds on our sets of shooter wheels are 100 and 130 fps at maximum motor output. We generally run it between 60% and 70%. I know we've got a lot of slip. So, the answer is just really, really fast.
It's a fast enough RPM that the difference between VEX hex bearings and VEX ThunderHex bearings may be necessary to investigate.
Sounds like we are pretty far away from the Aim High 12fps speed limit.
You know those gravitational waves you keep hearing about recently? Those weren't created by colliding black holes, they were created by our boulders colliding with the opposing alliance's tower.
#10
Im not really sure what ours is running at. It was decent speed when we had mini cims geared 1:1 with 3" of compression, but we put SpinBoxes on the mini cims so its geared 1:1.67 now. The wheels are spinning at roughly 10,000 RPM. We are still working on the final arm/ shooter assembly so we don't even know how well this will work compared 1:1.
#11
Worst rule ever...
#12
Ours shoots fast enough to take out exit signs and castles at range
#13
Here´s a video of our shooter, its faster than it looks!
https://youtu.be/5XZUleXc4XM |
#14
At events around the world, pit scouts will ask pit crews "how fast is your shooter" and the correct response is "faster than it looks." |
#15
Looking forward to the design where "low bar capable" + "high exit velocity" != "blockable". Is the flattest parabola really the best parabola?
