Go to Post Design is iterative, right? - JesseK [more]
Unread 17-02-2016, 23:44
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: paper: Parabolic Trajectory Calculations
Originally Posted by Hugh Meyer View Post
How would we measure the terminal velocity?
My first thought is a football stadium and a radar or ultrasonic speed gun. The procedure is pretty obvious.
If you don't have a speed gun, a strobe of some sort, including the video method suggested by Ether would be next.
As for 3946, we did the air-resistance-free calculation, added about 50%, tested that we had more than we needed to hit the goal at the ranges we wanted, then we'll back down based on empirical launch data until we hit the goal at the desired range (this year, with our rear bumper in the outer works). Not as elegant as the full-physics solution, but we've built several high-percentage launchers using this paradigm.
