Go to Post Having the foolish belief that you can win a match in which you are completely outgunned will drive you to develop a winning strategy. - OZ_341 [more]
Unread 21-02-2016, 00:50
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
pic: JP Swerve
Unread 21-02-2016, 00:51
asid61 asid61 is online now
Re: pic: JP Swerve
Looks good. The only thing I would be worried about structurally is the use of MDF over plywood or something.
42 rpm for turning the module seems really slow. The original 100rpm of the motor could be a better fit. In the picture it looks like the larger gear is on the window motor, are you sure that it's not 100 x 2 = 200rpm?
Why gears over belts for the first stage?
Are you using this for this year?
Unread 21-02-2016, 02:09
Chak Chak is online now
AKA: Thomas
FRC #4159 (Cardinalbotics)
Re: pic: JP Swerve
Looks good. But if you are planning on using this for Stronghold, on the slight off chance that you go over the rough terrain the wrong way, you might have the gear next to the wheel or the upside-down CIM scraping against the steel rough terrain.
Unread 21-02-2016, 19:51
NWChen's Avatar
Alum
Re: pic: JP Swerve
We were concerned about plywood's tendency to splinter. Is plywood stronger for this purpose than MDF?
My bad. The ratio is 2:1 for 84*2 = 168rpm.
This swerve module is designed to be fairly low-cost, and we had access to most of the gears used in the first stage (as opposed to compatible belts/pulleys). Money is also the reason that it's fabricated largely from wood, not aluminum.
The swerve module is being used for a robotics side project, not for Stronghold, although I'd love to see what 16, 2451, etc. have brewing for this year's challenge.
2012 - 2015 • Team 2601
Unread 21-02-2016, 20:02
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Re: pic: JP Swerve
Yes. 1/4" Baltic or Finnish birch plywood (not lauan or cheap 1/4" ply) will be much stiffer than 1/4" MDF.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
