Go to Post And I'm sure I speak for most if not all of CD when I say: "How can we help you do that?" - EricH [more]
Unread 22-02-2016, 02:50
Steven98's Avatar
Steven98 Steven98 is offline
AKA: Steven Crosby
FRC #2386 (The Trojans)
Steven98 is an unknown quantity at this point
pic: another view of Moose
Unread 22-02-2016, 02:52
DaveL DaveL is offline
FRC #2976
Re: pic: another view of Moose
Very interesting arm.
What is the purpose of the "flipper doddles"; made up word for the aluminum pieces on top of your arm.
Also, what does the drill-motor/red roller do?
Unread 22-02-2016, 11:15
jagow100's Avatar
jagow100 jagow100 is offline
FRC #3539 (Byting Bulldogs)
jagow100 is an unknown quantity at this point
I'm not a part of the team but they probably extend so they can hang from the bar.
3539 Programming Lead
The Programming Lizard
Unread 22-02-2016, 12:18
cad321 cad321 is offline
AKA: Brian Wagg
FRC #2386 (Trojans)
The flipper doodles (will have to suggest this to the team as the new official name for them) are used to climb. Our arm goes vertical, extends up and the flipper doodles grab the rung to climb. The drill motor is used to power our intake. It is a 1/2in hex shaft with some 2 7/8th bane bot wheels and surgical tubing flaps.
This year we tried to develop as much functionality into one main component as we could. So we ended up developing this arm. It helps us go over the categories A and C defenses, allows us to climb and score in the low bar, all weighing in at less than 25 lbs. So our practice robots arm can be our with oldie allowed e to use as a spare part. The whole arm cam be swapped in about 5 minutes if needed. Perfect for timeouts during elims.
Unread 22-02-2016, 13:03
waterbott's Avatar
waterbott waterbott is offline
FRC #1683 (Techno Titans)
waterbott is an unknown quantity at this point
What are you using to actuate the entire system? DART Actuator?
Unread 22-02-2016, 13:31
AKA: Brian Wagg
FRC #2386 (Trojans)
It is a linear actuator. However because the dart actuator is rather expensive (at least for us) we went out and got a linear actuator from princess auto down the road. It happened to be almost a perfect swap for a bag motor, has built in limit switches (which we re wired to go to the roborio, not the motor). Including the bag motor it cost us around $120-$130 canadian.
