Go to Post I mean really, have you ever tried to schedule Dean and the scuba diving trainer in Manchester in winter? ;) - Billfred [more]
Unread 22-02-2016, 17:57
Clayton Summerall's Avatar
Clayton Summerall Clayton Summerall is offline
FRC #4587 (Jersey Voltage)
Clayton Summerall is on a distinguished road
Lightbulb Re: pic: 2877's 2016 Robot
How did you fuse the poly???
Unread 22-02-2016, 19:05
Data Nerd
FRC #0079
Bumpers?
Unread 22-02-2016, 19:43
EricH EricH is offline
Originally Posted by Andrew Schreiber View Post
Bumpers?
A problem, by the looks. Something about an articulated frame perimeter, or stuff being outside the frame perimeter.
Unread 22-02-2016, 22:16
Mammaloon's Avatar
Mammaloon Mammaloon is offline
Optimistic Engineer
AKA: C Mastoras
FRC #2877 (LigerBots)
Mammaloon has a spectacular aura aboutMammaloon has a spectacular aura about
Ahh. I knew I forgot to mention something. This picture was taken 3-4 days ago, and since, an actual frame perimeter and bumpers have been mounted on. The actual frame perimeter is a bent plate that has been stood off from the 8020 so that there is a 1/4" gap between the plate and the treads.
Unread 22-02-2016, 22:23
Mammaloon's Avatar
Optimistic Engineer
AKA: C Mastoras
Some of the poly-cord may have been fused in the making of the 2012 robot. See maxwellfire's answer below for more detail on poly cord fusing.
Unread 22-02-2016, 22:27
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Originally Posted by Mammaloon View Post
Some of the poly-cord may have been fused in the making of the 2012 robot, but we simply nested the ends within each other and ran over it with a heat gun.
I'm confused are you saying you used parts made for your 2012 robot or am I reading that wrong. As an LRI I'm hoping I'm reading that wrong.
Unread 22-02-2016, 22:33
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
Are you saying cutting and re-welding polycord that was used on an old robot is illegal? Wouldn't used polycord (if you cut out the previously welded part) be almost indistinguishable from new polycord?
tumblr | twitter
VEXU UMN (2015-??)
Volunteer since 2011
Unread 22-02-2016, 22:46
Maxwellfire's Avatar
Maxwellfire Maxwellfire is offline
AKA: Max Tepermeister
Maxwellfire is an unknown quantity at this point
The Polychord is not the same chord as what was on our 2012 robot (it's a much smaller diameter in fact). We merely took inspiration from our 2012 intake. I think Mammaloon is a little confused .
despite that, I didn't think that it was illegal to reuse material from another robot, especially if its dimensions/length was changed.
To bond the polychord we made a wooden jig and then used a lighter held underneath to heat the chord until it became liquidy. It took a lot of bad joins to come up with a method that actually worked (if anyone is interested I'll share the specifics)
Awesome use of servos.
Thanks! We hope to be able to use them to angle our shot consistently. (maybe even some left to right aiming if the programmer are up to it ) We currently have new servos on order since the 12 dollar no name ones we were using kept dying... We went with a hitec hs85mg.
Unread 23-02-2016, 01:31
Engineering Coach
If they used the fused portions from the 2012 robot then yes it would be illegal. The previous comment said that the cord was fused for their 2012 robot, those connections would be illegal.
Unread 03-03-2016, 08:15
trumpthero786's Avatar
trumpthero786 trumpthero786 is offline
What Part of the Sandwich Are You?
AKA: Humza
FRC #2729 (Storm Robotics)
Team Role: Electrical
Rookie Year: 2015
trumpthero786 will become famous soon enough
nice beaver tail
CLAP CLAP WHOOSH!
2015 - Hatboro Horsham - Quarterfinalist with 272 and 5181 - Entrepreneurship Award
2015 - Seneca - Quarterfinalist with 316 and 5684 - Engineering Inspiration Award
2015 - MAR Championships - 50th Seed - Quarterfinalists with teams 1923 and 11
2016 - Hatboro Horsham - Team Spirit Award
2016 - Seneca - Gracious Professionalism Award
"nice beaver tail"
