Go to Post You will find friends among all FIRST students who will become very good friends of yours, will care and help you with anything that you need help with. This is my personal opinion, If you are hooked, dont ever let it go. - Arefin Bari [more]
Unread 22-02-2016, 22:46
Maxwellfire's Avatar
Maxwellfire Maxwellfire is offline
AKA: Max Tepermeister
FRC #2877 (LigerBots)
Maxwellfire is an unknown quantity at this point
Re: pic: 2877's 2016 Robot
The Polychord is not the same chord as what was on our 2012 robot (it's a much smaller diameter in fact). We merely took inspiration from our 2012 intake. I think Mammaloon is a little confused .
despite that, I didn't think that it was illegal to reuse material from another robot, especially if its dimensions/length was changed.
To bond the polychord we made a wooden jig and then used a lighter held underneath to heat the chord until it became liquidy. It took a lot of bad joins to come up with a method that actually worked (if anyone is interested I'll share the specifics)
Awesome use of servos.
Thanks! We hope to be able to use them to angle our shot consistently. (maybe even some left to right aiming if the programmer are up to it ) We currently have new servos on order since the 12 dollar no name ones we were using kept dying... We went with a hitec hs85mg.
