Go to Post I learned... that I need to learn more. - Erin Rapacki [more]
Unread 23-02-2016, 18:17
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
pic: FRC 319 Presents: Bob 2016
Unread 23-02-2016, 19:42
Professional Stat Padder
Re: pic: FRC 319 Presents: Bob 2016
I see those angled bumpers planned for a future mechanism to be added on.
(2015-Present)
Unread 23-02-2016, 19:47
Robotics Engineer
Yep! We're working with the engineers at our premiere sponsor, Symbotic, to develop a climber.
Unread 23-02-2016, 20:54
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
How are you planning on dealing with r28?
Andrew Basse
Unread 23-02-2016, 21:36
Robotics Engineer
By having numbers on all four sides? I'm not sure I understand the question.
Unread 23-02-2016, 21:39
Yeah, I'm not sure how your numbers are applied, but as I read it you need numbers on all sides or visible from any side.
I just know if we had our bumpers looking nice, the last thing I'd want to do is add numbers after the fact. Unless your using paint?
Andrew Basse
Unread 23-02-2016, 21:41
Robotics Engineer
Ah. Simple answer is that we use the stickers from AndyMark. Full answer is that we intend to remake the bumpers with a better construction method.
Unread 24-02-2016, 01:33
DaveL DaveL is offline
FRC #2976
Nice job on the pickup / shooter mechanism!
How do you direct the boulder into the center so it can be loaded into the shooter?
Unread 24-02-2016, 15:56
Robotics Engineer
We have a guide on either side making the bot look kind of like Plowie/Dozer.
Unread 24-02-2016, 16:11
Nate Laverdure's Avatar
FRC #2363
Wow, huge opportunity lost here.
Unread 24-02-2016, 16:47
Robotics Engineer
patience
