Go to Post I had a fight with my robot once during competition. I felt bad about it and apologized. - Tommy F. [more]
Unread 28-02-2016, 11:33
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
pic: Wheeled shirt launcher
Unread 28-02-2016, 11:36
Sperkowsky's Avatar
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Re: pic: Wheeled shirt launcher
Ooooh very nice.
My team was discussing making a WCD pneumatic t-shirt cannon as an offseason project but we were discouraged away from it slightly due to the cost of making a safe t-shirt shooter.
This looks like a pretty cheap (around $300 - $400) and easy build using the a build style more applicable to an FRC robot. Maybe we could work together to make it a reality.
Unread 28-02-2016, 12:33
swaxman12345's Avatar
swaxman12345 swaxman12345 is offline
Team Member
AKA: Sasha Waxman
FRC #2512 (Daredevils)
Rookie Year: 2015
swaxman12345 is an unknown quantity at this point
Do you think you could upload the CAD model? I'd like to take a closer look if possible.
Beware the Kraken, Jebediah. - Bill Kerman
Unread 28-02-2016, 12:49
I'm not sure how well wheels would interact with the shirts. One would have to make sure that the shirt doesn't get torn up or unroll while shooting.
What if you used a can of some sort to hold the t-shirt in while going through the wheels, but gets hardstopped before it can leave the cannon? That way the t-shirt gets acceleration but the shirts are not damaged.
Love the use of 2 stages btw, that seems like it would be useful to get longer distances.
Unread 28-02-2016, 12:50
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Have you done any tests with using a wheeled shooter to propel shirts? I'm wondering how much grip you would get, if the wheels would mark up the shirt from slipping, etc.
2016: Lake Superior WFFA
Unread 28-02-2016, 13:39
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
My thoughts exactly. At first glance I actually thought that the casing for the shirt was propelled by the first set of wheels, then stopped before contacting the second set, wherein the shirt gets ejected from the casing by momentum and taken by the second wheel set to be shot. Now I realize that the shirt gets propelled all on its own. I wonder how tight of a roll the shirt needs to get any meaningful compression from the wheels?
Unread 28-02-2016, 16:10
NWChen's Avatar
Alum
Team 1058 approached the idea several years ago fairly successfully.
In testing, a very tight roll is not even necessary to eject a properly ranger-rolled shirt. When the forces on the shirt are perpendicular to the direction of the roll, it seems to be difficult to unravel even by hand.
The shirt compresses to about 2/3 of its normal diameter for an effective shot (independently tested with the first shooter stage and second shooter stage, but not together). The wheels do not mark up, although a few cloth fibers sometimes gather after several shots.
To clarify, I've already built this device. There's a bit more wiring to do before it's ready to test in its entirety. Indexing with the ratchet and pawl is functional. The total price of the unit is approximately $350.
2012 - 2015 • Team 2601
Unread 28-02-2016, 19:05
NWChen's Avatar
Alum
STEP file: https://drive.google.com/file/d/0Byg...ew?usp=sharing
Unread 28-02-2016, 19:23
slickvic2252's Avatar
slickvic2252 slickvic2252 is offline
mentor
AKA: Theren Vickery
FRC #2252 (Mavericks)
slickvic2252 is an unknown quantity at this point
4451 had a wheeled launcher at palmetto this year.
Unread 28-02-2016, 20:55
That's awesome then! Do you have any videos of it shooting?
Unread 28-02-2016, 23:37
BetaHelix's Avatar
BetaHelix BetaHelix is offline
FRC #4646
BetaHelix is an unknown quantity at this point
Have you tried using mini-cims rather than full CIMs? It would be slightly smaller and the wheels would spin faster.
Also do you know if this would work belt fed or with saboted shirts? (Just hypothetically. )
Unread 29-02-2016, 12:54
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
I was surprised to see one of 1058's old projects in here! That t-shirt launcher was a cool little mechanism- the indexing system you designed reminds me of ours, except you used motors and servos instead of pneumatics, which increases simplicity and eliminates the need for two separate power systems. To the note about the shootability of the shirts- in that video, we had wrapped the shirts in masking tape so that they would maintain their shape better.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 29-02-2016, 13:11
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud of
We are currently using a pneumatic 3 t-shirt shooter but for the offseason are looking to upgrade to something similiar to the Poofs uniquely styled 10 t-shirt shooter. But yes I do admit, the pneumatic plus the compressed air storage is a little pricey.
Team member 2004-2008
Team mentor 2008-2014
http://team1708.steelcityrobotics.or...tics/Home.html
"12 years as a student and mentor and proud of it"
Unread 29-02-2016, 13:22
JoshWilson's Avatar
JoshWilson JoshWilson is offline
FRC #0230 (Gaelhawks)
JoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to all
Nice job, I especially like how you're able to do it with the wheels, and have that work well. Hope you'll post a video and let us see it in action!
Unread 29-02-2016, 14:38
NWChen's Avatar
Alum
I plan to get some Mini CIMs in a few weeks and try those out.
I had considered a magazine-like approach to loading shirts, but a revolver-like cylindrical action seemed less prone to jamming and more aesthetically pleasing.
If you have any images/video/documentation of 1058's device beyond that video, I'd love to see it.
Thank you. I don't expect to have videos up within the next 2 weeks on account of midterms unfortunately.
