#31
Re: #25 Chain
#25 is a total dream if you use it right, we used it wrong once after a couple former mentors tried to sell some fiction one year and of the 4 chain runs we had on that robot at Alamo in 2014, we threw all of them at least once. In 2014 because of snow we were allowed to bring in 45 pounds of withholding so we left the drivetrain out of the bag before Virginia and rebuilt the whole thing. Every other time the chain has been properly tensioned and spaced and we have loved it. |
#32
Re: #25 Chain
Re: #25 Chain
In round numbers: 8in wheel diameter 2in chain wrap diameter µF = 1.3 Robot weight = 140lbf Assume: All weight on one wheel (possible, if not likely, during defense crossing) Drive is traction-limited (certainly the case at 6ft/s with 3 CIMs per side!) Chain tension: 140lbf*1.3*8in/2in = 730lbf Breaking strength of #25 is around 780lbf, giving one a FoS of 1.1, and virtually guaranteeing yielding in the chain. This case is quite conservative, but being conservative in drive-train stress considerations is probably a good idea. For consideration: in our chain-snapping 2016 drive train the calculated tension was 550lbf. Changing to #35, with a breaking strength of about 1900lbf, did the trick. In prior years we've had chain tensions in the 150-200lbf range. Having a FoS of 3+ versus chain breaking strength is probably a good idea. |
#34
Re: #25 Chain
The importance of robustness in a drive train cannot be overstated, literally--if your robot can't drive around, you can't compete***, no matter how awesome your upper mechanical systems happen to be. ***Except last year, maybe. But let's not talk about last year, like, ever. Let's file it away in the Mental Folder of Things that Do Not Actually Exist, like HIGHLANDER 2. Ahhhh, that's better. |
#35
Re: #25 Chain
I think I recall a similar thread a couple of years ago which went in a different direction, with a lot of folks emphasizing the qualities of #25. My team has been using #25 for last several years with no problems, and we used it on our drive train this year. I guess we will see how well it holds up next week. Maybe I should bring sullied to do a "quick" swap in AZ if necessary.
#36
Re: #25 Chain
Looking at this site here: http://www.partsforscooters.com/PFS-Chain-Chart
I was able to see a difference of thickness between #25 and #25H chain (roughly .24mm per plate, for overall thickness of about 1mm). I am looking for a side-by-side tensile strength comparison to determine if it's truly worth making a jump from mcmaster #25 to a #25h change. If I find one, I'll post it here. |
#37
Re: #25 Chain
The max allowable load column is synonymous with max recommended working load. Converted to lbf, it is 165 lbf for #25, 242 lbf for #25H. Average tensile strength is 992 lbf and 1323 lbf, respectively. These values are a little higher than I recall from past research, but at least gives you a side-by-side comparison. We have used #25 chain successfully in drive and manipulator applications since our rookie year in 2004. I would definitely recommend #25H chain over #25 in all applications, the weight penalty is marginal for the added strength. I generally avoid #35 chain at all costs, due to weight, but if you are having failures with #25, I would say switching to 25H alone will likely be a marginal improvement - try to increase sprocket size as well. If you have the weight, consider #35 for the added reliability. Drivetrain failures are are the worst possible failure point, as it leaves you useless on the field. Whenever possible, I encourage direct-driving at least one wheel, so that no chain is a single-point-of-failure to half your drive. If you must have chain directly from your gearbox, then I would consider #35, as failures there are unacceptable. This year, with 8WD using 8" pneumatic tires, we chose to direct drive one center wheel, use #35 to the other center wheel, and #25 to the outer corner wheels. The idea is a compromise between weight and reliability - no #25 chain failure will leave us unable to drive reasonably well, as it would only cut power transfer to one corner tire. I think a huge part of the problem people are seeing is the dramatically higher forces involved with the larger tires paired with smaller sprockets. For years FRC drive trains have been evolving toward smaller wheels and less gearbox reduction, which pairs favorably with transitioning to #25 chain. In James' example case, if you were instead running 4" wheels, the max possible chain tension would drop to 365 lbf, and SF would increase from 1.1 to 2.1. I agree that his scenario is conservative, but I think most teams (running live-axle WCD, at least) are using even smaller sprockets than he calculated. Consider that the largest hubbed #25 sprocket Vex sells is 22T, with a pitch diameter of 1.75". |
#38
Re: #25 Chain
Where did you find it? Everywhere I've looked is sold out.
#39
Re: #25 Chain
A google search for a "221 chain tool" (that's what we call it since all of ours are 221 branded) will lead you to 221's page for the item which they no longer sell....
...but the page has a link for the tool sold elsewhere and is available from that seller. |
#40
Re: #25 Chain
We usually use #25 chain in our drive, but not this year. We decided not to push our luck with 8" wheels and a field that promises to provide more drive train abuse than usual.
#41
Re: #25 Chain
Re: #25 Chain
Re: #25 Chain
Are shafts somehow immune to problems? Live axles bring there own problems. Gear teeth are not infinitely strong. And so on. Make sure you have a reliable drive train. That is the take away. There are a lot of ways to get there, but you really need to get there. Dr. Joe J. |
#44
Re: #25 Chain
Of course I never meant to imply no-maintainace chain systems weren't possible, just harder get right with smaller chain. Quote:
![]() Quote:
#45
Re: #25 Chain
I'll have to make it a goal in the off-season to properly test a dry lube, so I can have confidence in it. Quote:
Of course very reliable dead-axle drivetrains are possible without direct-drive. Attention to design details, such as well-supported shafts, ridgid/robust frame construction, careful component selection (chain/belt type, sprocket/pulley diameter, etc.) and reliable method of chain tensioning are all still critical for success, no matter what drive style you choose. In this era where there are a selection of proven COTS gearboxes to choose from, I would generally agree with Chris that most teams will have more issues with assembly and implementation than with the gearbox components themselves. We have run both live and dead-axle drivetrains, with varying degrees of success. In my time in FIRST, we have experienced: - Bent drive shafts (2007, poor steel grade selection) - Stripped gear teeth (2012, inadequate lubrication, fortunately happened post-season) - Sheared shafts at poorly placed E-clip grooves - Set screw failure (2007, never use set screws and D shafts in reversing load situations, and never in drive trains!) - More chain tension issues than I can count And many other drive failures ranging from nuisance maintenance items to crippling season-killers. Experience can teach you what not to do, but it also proves that there are many ways to get it right. |
