Go to Post Think outside the bot. Find a different regional someplace you never considered before. There's plenty of them. - Koko Ed [more]
Unread 16-03-2016, 15:43
kbrowncny's Avatar
kbrowncny kbrowncny is offline
Mechanical Engineering Mentor
AKA: Kevin Brown
FRC #2168 (Aluminium Falcons)
kbrowncny is an unknown quantity at this point
Re: pic: Rhino track broken 4
FRC Team 229 used a similar type of tank tread bought from an automation supply company in 2012. The belts were also steel lined and had a similar breaking strength. The team tore through plenty of them and at $220 a piece it was a big problem for our wallets. What we later determined after busting through at least 3-4 sets of belts that tensioning is a key part of belt drive. Due to the nature of FRC you are constantly altering directions and going from tension to slack on the drive belts. If a belt slips off your drive cog or becomes miss-aligned it has high potential to form a crack at the edge of the material. As soon as that happens there is a point of imbalanced stress concentration on the cross section. This game in particular has plenty of points (ie steel objects that could fracture a belt). My guess is that your issue initiated as a small hairline fracture in the material, then after time on the field alternating between tension and slack then applying a peak stall the belt reached its max.
Using these belts I would make sure to keep an eye out for any small sources of cracks in the flexible liner. Once this happens you may need to replace the belt to be safe. The other thing I can recommend from my 2012 experience is that you need to make sure you have a way to tension the belts (statically, or passively in both directions) and not over tension the belts i.e. applying too much torque to your turnbuckle. You may be surprised how much force you can put on those belts through tensioning.
