Re: Your tall opaque robot is now illegal
Chief Delphi's Greatest Hits vol. 47: Overreactions to Q&A responses
Hmm... could I get the entire opposing team red carded by attaching my camera to the wheels? So anything above like 1 inch would be intending to block my camera.
Obviously that is a bit ridiculous, but blocking a camera seems like a good strategy and if a robot can only shoot on visual cues then they have issues. We had that issue in St Joe when the field rejected our camera (we had it configured incorrectly) and we corrected the issue. We can now shoot with or without the camera. |
A tall robot (or piece of polycarb, or a drop cloth held by a robot) doesn't interfere with the proper functioning of the sensor. The sensor is still working just fine - it just can't see what the operator wants it to see. Shining an IR laser at their camera, now THAT would be interfering with the proper functioning of the sensor.
How about 95's arm? When its vertical it's fairly tall and does a passable job of blocking shots. That wasn't a specific design goal, but we're happy it does it. I imagine it'll also block a cameras view of the tower.
Is our arm now illegal if a RI decides it is? Because it seems they certainly have the precedent to make that call now. ![]() What if I put a range sensor on the front of our robot and argue that its used to sense distance from the tower for shooting guidance, and if a robot gets between the tower and my robot then it's interfering with my robots sensing capabilities? That's obviously ridiculous, so why are cameras any different? |
With regards to your arm or other "tall opaque" objects, the same logic applies. If the design of the device is obvious that it is not specifically designed or intended to block camera vision, then the Lead Robot Inspector is unlikely to deem it illegal. This ruling is not a game changer. |
You are far too trusting in the ability of random volunteers to exercise restraint and common sense when making their rulings.
Lead robot inspectors are not random. They are typically seasoned FRC veterans. We've already had one comment in this thread regarding his interpretation of this Q&A response.
So question, if a team is obviously shooting high arc lob shots over a blocker's height limit, will the refs call the messing with sensors rule if the blocker attempts to "block" the shot but is really just blocking the camera? Especially if the blocker wasn't "intending" to block cameras but just block shots.
#10
This Q&A is an inspection issue, not a match play issue. If you violate this rule it would be during inspection, not during a match. There is no gameplay associated rule that penalizes teams for standing in front of cameras or whatever.
#11
At CVR, the LRI left it up to the Head Referee's discretion. Teams who had passed inspection were later forced to modify. After helping an alliance partner install a blocker, the LRI "suggested" that windows be added because the head referee would rule it a violation of R9-A.
#12
-Brando |
#13
Except in this instance, Rules for Intent(even supposed intent) have been laid out.
#14
Every shot is different - some will be clearly unblockable, others will be right on the edge, but unblockable and others will be right on the edge, but sometimes blockable... Oh and in doing all of this, your camera was completely screened because I was trying to block your (maybe) unblockable shot... -Brando |
#15
