Go to Post While youth is wasted on the young, in FRC knowledge can be wasted on those a bit older. - IKE [more]
Unread 04-04-2016, 01:03 AM
Boltman Boltman is online now
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: pic: Simple hook delivery system
Very cool.
What happens when it misses does it ever have the potential to go outside 15"?
How do you aim it?
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star #21 | Galileo Division #91
Unread 04-04-2016, 07:52 AM
joeojazz joeojazz is offline
FRC #5712
joeojazz is an unknown quantity at this point
How did you use the rubber band like a crossbow if it was inside of the pneumatic cylinder. Also could you fit under the low bar with it?
Unread 04-04-2016, 08:09 AM
connoc1 connoc1 is offline
FRC #2084 (Robots by the C)
connoc1 is an unknown quantity at this point
What I believe they did was use that red stick thing to push back an elastic band (probably surgical tubing), and then used the pneumatic cylinder to hold back the elastic band and keep it there until it was quickly released by actuating the cylinder.
FRC 2084, Robots by the C
Last edited by connoc1 : 04-04-2016 at 02:03 PM. Reason: CD censored a word that in that case shouldn't have been censored
