Go to Post Real projects have good and bad aspects, problems that must be dealt with, and lots of things that dont make any sense from your side of the fence. - KenWittlief [more]
Unread 04-04-2016, 08:09 AM
connoc1 connoc1 is offline
FRC #2084 (Robots by the C)
connoc1 is an unknown quantity at this point
Re: pic: Simple hook delivery system
Originally Posted by joeojazz View Post
How did you use the rubber band like a crossbow if it was inside of the pneumatic cylinder. Also could you fit under the low bar with it?
What I believe they did was use that red stick thing to push back an elastic band (probably surgical tubing), and then used the pneumatic cylinder to hold back the elastic band and keep it there until it was quickly released by actuating the cylinder.
FRC 2084, Robots by the C
Last edited by connoc1 : 04-04-2016 at 02:03 PM. Reason: CD censored a word that in that case shouldn't have been censored
