Go to Post Legend has it that Brandon installs the server in a bulletproof case shortly before Kickoff. That way, when the server explodes, the damage to surrounding things is minimal. ;) - Billfred [more]
Unread 05-04-2016, 14:22
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Re: pic: Winch-atize me, Cap'n!!
Originally Posted by pilleya View Post
Unfortunately Andymark does not sell 18 tooth steel gears with a 1/2 inch hex bore.
While the final stage gears might not be able to take the stall torque generated by the 775's, the ratchet means that the motors should never need to be be stalled.
They do sell this 19 tooth one, which I bet would also work.
http://www.andymark.com/Gear-p/am-0176.htm
We wound up using one of these paired with a this mecastercarr gear that we machined the bore ourselves. http://www.mcmaster.com/#6325k73/=11up3mm
Just trying to help.
It wasn't our first choice, but is nice not breaking teeth every other match.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
